Go Back   Automotive Forums .com Car Chat > Racing > Technical
Technical Discuss different strategies and theories of the racing aspect.
Old 01-15-2004, 06:51 PM   #1
raceya
6 speed vs. 5 speed
I have seen some cars offered with a 5 or 6 spd manual transmission. I'm just wondering what is the advantage of one over the other. Is the 6 spd. have two overdrives? What is closed ratio? Thanks.
raceya is offline   Reply With Quote
Old 01-16-2004, 04:30 AM   #2
MustangRoadRacer
MustangRoadRacer's Avatar
Re: 6 speed vs. 5 speed
I believe it is CLOSE ratio, meaning the gears are relatively close together.
6 speed is generally a better transmission because it has nice low gears (123) pretty standard 4th and 5th, and 6th is an overdrive gear.
my T56 has a .62 6th gear, which helps me get great mileage on the freeway.
they are usually more expensive however.
Mustangs are nice, but I'd rather have one of these...
MustangRoadRacer is offline   Reply With Quote
Old 01-16-2004, 09:22 AM   #3
kfoote
The exact gearing varies car to car, and sometimes even within cars (early Corvette C5 6-speeds are different than later C5 6-speeds). it depends more what the exact gear ratios are more than anything else. Usually the benefit is you can get closer ratios and still have a useable overdrive for highway driving.
2004 Subaru Impreza WRX STI (daily driver)
1999 Mazda Miata (track car, slow, but finished the SCCA Runoffs)
1987 Porsche 944 (being rebuilt)
kfoote is offline   Reply With Quote
Old 01-17-2004, 01:41 PM   #4
MKIISupra
most 6 speed trans have 2 overdrives. 5th and 6th are often overdrives. I prefer a 5 speed for lighter weight.
MKIISupra is offline   Reply With Quote
Old 01-18-2004, 01:11 AM   #5
MustangRoadRacer
the differnce in weight is like 10-20 lbs.
Old 01-19-2004, 07:36 PM   #6
flylwsi
Send a message via AIM to flylwsi
this isn't an easy question...
in a car that has both available, like a miata, the final drive isn't much different...
it's just that they push the rest of the gears closer together...
it's all about the gearing though. you can have a great 5 speed, and not need the 6th gear...
the 6th gear in most cars on the street, like the mustang/viper/vette/f-body cars is an overdrive only, and used to keep your freeway mileage respectable...
in other cars, such as the miata, the gearing of the "overdrive" in the 5 and 6 speed is the same, but the rest are closer...
2 different schools of thought...
1. you add an overdrive to a 5 speed (i know that's oversimplified, but that's kind what it is with the tremec in those cars)
2. you keep the top gear the same, and push the rest closer... (again, oversimplified, but for all intensive purposes)
this is why you can't compare my 5 speed prelude to a 6 speed supra, and say that the supra is better/worse b/c of the # of gears...
flylwsi is offline   Reply With Quote
Old 01-21-2004, 06:20 AM   #7
MKIISupra
did you just say that the differance is only 10-20 pounds. It seems like you are saying that is not alought of weight. Well, that is a lotta lotta lotta weight. JGTC guys take grams off of cars, taking 10-20 pounds off is more helpfull than you think. I am stripping my whole entire car, no iterior AC no rear seats no speakers or anything.
Old 01-21-2004, 07:41 AM   #8
MustangRoadRacer
that's great.
Most people here don't have race cars where 10-20 pounds would make a difference.
And for the record, the performance gain could outweigh the weight disadvantage, depending on the transmission.
Old 01-22-2004, 03:09 PM   #9
flylwsi
that's great.
exactly.
you could counteract 10lbs. by taking your SPARE TIRE OUT when you're racing.
oh wait... that's still a weight loss...
we drive street cars. not track-only vehicles...
Old 01-22-2004, 04:09 PM   #10
89Turbo944
89Turbo944's Avatar
Fromt he cars i have driven with a 6 speed, Tibaron(cant ever speel right), Corvet, Lambos, Ferrari's.
The Tib had a close gearbox. Beaning you would have to shift sooner from first to second than you would in a 5 speed box. A 6 speed usualy allows somewhat better acceleration, and retains teh top speed as well. I had the same experance with the other cars as well.
Thats just what i have experanced tho.
89Turbo944 is offline   Reply With Quote
Old 01-22-2004, 05:28 PM   #11
Volvord 784VC
Transmission weights:
T5 5 speed - 75 lbs
T56 6-speed - 115-129 lbs (depending on gear ratio)
Tremec TR 3450/3550/ 5 speed - 113 lb
So converting from a T5 to a T56 will increase the weight 40-55lbs which you would notice, but converting from a Tremec TR to a T56 will not have any noticable weight increase.
Volvord 784VC
350HP Ford 302 Powered Volvo 740 Turbo
http://www.volvord.com New site
http://www.telusplanet.net/public/gilesij/Volvord/ Old site
Volvord 784VC is offline   Reply With Quote
Old 01-22-2004, 07:34 PM   #12
MKIISupra
Why not use a 5 speed and remove the spare . I mean, most people dont like doing this, but i dont care, I like spartan, I am completely removing everythign from my supra. The interior will only consist of driver and pass seat, no rear seats, no carpet, no plastic interior, no insulation, no radio or anything.
Old 11-22-2004, 10:41 PM   #13
tricksaturnsc2
The shorter gearing of a 6th gear will easily beat the added weight over a 5 speed!!! I have an s2000 that comes with 6 speed 4.1 final gear & put 4.77 in it & i lost .5 seconds on my 1/4 mile.
tricksaturnsc2 is offline   Reply With Quote
Old 11-24-2004, 10:16 AM   #14
2of9
Well...think about the 02-04 Sentra Spec-V's and the RSX Type-S. Both come in 6 speed and both at a race (driver depending), i've seen the spec-v take out a RSX Type-S stock against stock, but its the driver...
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines"
--2OF9--
(DSM team specialist) ;D
#808/1000
2of9 is offline   Reply With Quote
Old 11-24-2004, 10:39 PM   #15
tricksaturnsc2
Yes well that proves nothing. The type s has no torque, obviously the more torque the less gears & the longer the gears are. And I bet if they made the 5 gears shorter it would be faster.
03 Accord Coupe V6 6-Speed VS. 03 Altima 3.5SE 5-Speed KoRnboy Altima 60 08-12-2007 10:17 PM
5 speed vs 6 speed Gotian Non Specific 27 05-20-2006 02:58 PM
5 speed vs 6 speed ashadiow Tiburon | Tuscani 8 03-09-2004 04:33 PM
