Go Back   Automotive Forums .com Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 04-14-2004, 01:50 PM   #1
1990whitez
Send a message via AIM to 1990whitez
Unhappy '90 z32 automatic transmission
Last summer I traded my 95 Eclipse for a 300zx, and in my mind it is still the smartest deal I've ever made. However, the car had some tranny trouble, its automatic transmission seems to skip second gear. I've heard this is a common problem in early z32s, as they used a very soft metal to fabricate the gears, I have also heard that the swap to 5-speed is too cost prohibitive? Lastly i have heard that nissan used the z's tranny in some infinitis, true or false? I would appreciate any knowledge on where I might acquire a dirt cheap tranny to get my white z terrorizing the Massachusetts highways again, as a college student's bankroll doesn't support a $2500 rebuild.
1990whitez is offline   Reply With Quote
Old 04-14-2004, 05:52 PM   #2
1viadrft
1viadrft's Avatar
Re: '90 z32 automatic transmission
Swapping in an MT? Not worth it, buddy. Better off buying a Z with MT already... The Nissan Z32 and the Infiniti J30 shared the same motor and tranny... but it's greatly reduced to LUXURY and not SPORTSCAR tuned. Dirt-cheap tranny? Good-Luck! The cheapest I can find is for $1,000...
1990 Z32 2+2 BLITZ SUS Intake, HKS ALC
My 1994 TT Supra For Sale: http://www.automotiveforums.com/vbul...d.php?t=623105
1viadrft is offline   Reply With Quote
Old 04-22-2004, 04:55 PM   #3
wht348tb
hi, I got VG30 na engine and at tranny from Japan.
I took from the car I was driven in japan. only about 55k mil on it. would you like to take a look?
wht348tb is offline   Reply With Quote
Old 04-22-2004, 05:14 PM   #4
1viadrft
1viadrft's Avatar
I heard that the JDM VG30's are not as built as the USDM versions... they tend to break down easily.
Old 04-26-2004, 09:20 AM   #5
zfreak_1125
swapping an AT to a MT isn't that cost prohibitive, provided you do the swap yourself. I had the same problem in my 90 NA and eventually the car became undrivable and forced me to replace it. i bought everything new except for the tranny(obviously) and the pedals(brake/clutch), and my swap only cost me about $1000...and that included shipping(since i'm overseas shipping is real expensive). so i'd say check ebay for a tranny or start calling local junkyards and see if they have one. if you want more info on what's required for the swap, either contact me or check out this site. they sell a whole kit of everything you need for $1850(TT transmission). hope this helps
www.z1motorsports.com
zfreak_1125 is offline   Reply With Quote
Old 03-03-2011, 01:38 PM   #6
txq45
Send a message via AIM to txq45 Send a message via Yahoo to txq45
Cool Re: '90 z32 automatic transmission
The transmission in the J30 is the same as the 300zx NA (RE4R01A)
the transmission in the q45 is the same as the 300zx tt except for a friction
(RE4R03A)
Rebuild kits are the same number for the J30 and 300zx
Different kit numbers for the Q45 and J30
The J30 ECU is a 16 bit and the pre 93 300zx is 8bit (8bit have a removable eprom) with the 16bit to upgrade you must either use a daughterboard with a 512K chip or you can do a Nistune upgrade and will interchange with the right rom file which you can get at www.aaa-hiperformanceauto.com plus they handle the built autos
txq45 is offline   Reply With Quote
96 Dodge Van 3500 Automatic Transmission Failure vince2010 Ram Van 7 01-14-2013 03:12 AM
01 Civic Automatic Transmission Shifts like...? Shrewz92 '01-'05 Civic 9 08-15-2010 02:45 PM
trooper 1993 3,2 Dohc , automatic transmission change windfast Trooper | SLX | Bighorn | Wizard 0 04-26-2010 12:21 PM
Automatic Transmission not so automatic keyplayah71 Park Avenue 2 10-19-2003 07:40 PM
