Go Back   Automotive Forums .com Car Chat > Dodge > General Discussion
Old 05-15-2014, 06:20 PM   #1
DebbieMarie54
1992 Dodge Spirit
My Spirit does not want to climb hills anymore. It loses power and overheats.
Plus now I'm getting about 8 miles to the gallon.
What could be wrong with my car?
Other than this it's doing pretty good.
Thank you.
Deb
DebbieMarie54 is offline   Reply With Quote
Old 05-15-2014, 07:18 PM   #2
Crvett69
Crvett69's Avatar
Re: 1992 Dodge Spirit
need to check your fuel and air filter, change the plugs if it has not been done in a while and get your exhaust system checked, may have a plugged cataletic convertor. usually will hear a hiss under car if they are totally plugged but not always
Crvett69 is offline   Reply With Quote
The Following User Says Thank You to Crvett69 For This Useful Post:
DebbieMarie54 (05-15-2014)
Old 05-15-2014, 07:39 PM   #3
DebbieMarie54
Is the fuel filter inside the fuel tank?
Old 05-15-2014, 07:43 PM   #4
Crvett69
Crvett69's Avatar
it could be in back by the gas tank or up front by the engine but it should not be inside the gas tank
Old 05-15-2014, 07:48 PM   #5
DebbieMarie54
My fuel filter was replaced a few years ago, and the mechanic told me it was inside the fuel tank, and that he had to remove the fuel tank to replace it. I'm sure I was lied to from what you are telling me now.
Old 05-15-2014, 07:51 PM   #6
Crvett69
Crvett69's Avatar
there is a fuel strainer/sock in the tank but filter is usually mounted outside the tank so you can change it without removing tank
Old 05-15-2014, 08:50 PM   #7
DebbieMarie54
Thank you. This is very helpful information.
