Go Back   Automotive Forums .com Car Chat > Car Audio
Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music.
Old 11-18-2005, 04:24 PM   #1
vinnym86
vinnym86's Avatar
Send a message via AIM to vinnym86
(Amp Install Q) Fusing my Battery
I've got 4gauge wire running from my soundstream to the battery. when i fuse it at the battery, what rating amp do i use? i know 4g will stand up like 150amps. I was talking to tech-support at Crutchfield and they said whatever fuse rating that's on my amplifier, (there are [3] 80amp fuses), that's the rating fuse i need at the battery... really!?
EDIT: sh*t my bad, there are [3] 25amp fuses on my amp.
The most beautiful thing we can experience is the mysterious... He to whom this emotion is a stranger, who can no longer pause to wonder and stand to rapt in awe, is as good as dead: his eyes are closed.
vinnym86 is offline   Reply With Quote
Old 11-18-2005, 06:01 PM   #2
ToyTundra
ToyTundra's Avatar
Re: (Amp Install Q) Fusing my Battery
there is some debate in this:
Some say the fuse should be equal to the maximum current the wire can carry
Others say the fuse shold be the same as the amp's fuses.
I use the first method, or less, so i would use 150A assuming it's not a real long run of wire
ToyTundra is offline   Reply With Quote
Old 11-18-2005, 06:21 PM   #3
vinnym86
vinnym86's Avatar
Re: Re: (Amp Install Q) Fusing my Battery
no, not too long, i'm guess-timating about 15ft at most, even that might be too much. from the trunk to the hood, civic sedan.
thanks for clearing that up. the amp kit i'm buying has a 80amp AGU fuse, but it looks cheap, generic. i dunno, i hear AGU fuses can be of poor quality sometimes. maybe a 150amp ANL would be better?
Old 11-18-2005, 09:08 PM   #4
PaulD
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
the third method (the correct one) is that you are protecting the BATTERY from a short circuit, so you should never exceed the battreries current capacity.
PaulD is offline   Reply With Quote
Old 11-18-2005, 09:22 PM   #5
vinnym86
vinnym86's Avatar
Re: Re: Re: (Amp Install Q) Fusing my Battery
haha, thnx for clearing that up
Old 11-19-2005, 05:14 PM   #6
ToyTundra
ToyTundra's Avatar
arn't batteries capable of 300-550A depending on model?
Old 11-23-2005, 11:36 AM   #7
PaulD
Audio Guy
that would be a MAX current rating ...... the avg or "RMS" current rating is actually roughly equal to it's reserve rating in minutes - don't ask me how they worked that out.
Old 11-23-2005, 12:01 PM   #8
germanyt
There is a manual you can order online that explains everything you ever need to know about impedence, power, amperage, etc., etc. Do a search for Mobile Electronics Certification Program. I'm about to start the course so I can get a part time job installing at a local shop.
(2) RE SX 15s (www.reaudio.com)
~6.5^3 net @ 35 Hz (polyfilled to increse vol. & lower tuning to 32 Hz)
(2) eD Nine.1s (www.edesignaudio.com)
1 Optima yellow top (www.optimabatteries.com)
1 Optima red top
200 amp alt (www.dbelectrical.com)
eDead V1SE2 250 sq ft
Big 3 (1/0 awg)
Pioneer DEH-P650 (www.pioneerelectronics.com)
Infinity Reference 5 1/4 comps (www.infinitysystems.com
Infinity Kappa 6x9s
MTX Thunder 3404
Power Acoustik TFT/LCD
Pyle DVD/CD/MP3/WAV/WMA player
germanyt is offline   Reply With Quote
Old 11-23-2005, 12:44 PM   #9
vinnym86
vinnym86's Avatar
yup, MECP. i need to start a class for that too.
Old 11-23-2005, 07:32 PM   #10
PaulD
Audio Guy
I have the MECP manual around here somewhere .... it had a number of mistakes in it (theory wise). I hope the newer ones are a little better.
