| Latest | 0 Rplys |
06-20-2007, 10:06 PM | #211 | |
GM S-Series Mod
Re: PCV Oil Catch Can, see what your engine is burning!
if you constantly let the filter get submerged in oil and what not it could clog. if you empty it before then, the filter should not clog. you can try to clean the filter every so often but i personally never had much luck doing so. i forgot you just swapped engines. I believe what you are experiencing is normal. When i first installed it on my old truck, the catch can filled rapidly for a week or so, then it would fill very gradually from then on. Other people have experienced the same thing. On my current truck, after the first week or two, i had to empty it once. Since then it has never gotten passed 1/4 of the way full.
2000 Chevy Blazer ZR2 Performance Mods: Numerous Suspension Mods: Some, but not enough Exterior Mods: Just Right 1987 Buick Turbo T Dark Red Low 11 sec sleeper .030 4.1 block, PT6262E, & other odds and ends.... My Cardomain Last edited by ZL1power69; 06-21-2007 at 07:38 PM. |
06-21-2007, 05:43 AM | #212 | |
sounds good thanks, yea i hit the filter with some brake clean and it whitened up some so i figure ill be fine as long as i dont let it do
http://www.cardomain.com/ride/783126 |
06-21-2007, 11:38 AM | #213 | |
good info
06-22-2007, 06:46 PM | #214 | |
I put one in my Burb and will do the blazer next
'92 s-10 4x4 EC p/u '99 Blazer LT '99 Suburban LT |
06-22-2007, 09:41 PM | #215 | |
GM S-Series Mod
looks like a nice install. i'm assuming thats a 350. post pics of your blazer's install also.
2000 Chevy Blazer ZR2 Performance Mods: Numerous Suspension Mods: Some, but not enough Exterior Mods: Just Right 1987 Buick Turbo T Dark Red Low 11 sec sleeper .030 4.1 block, PT6262E, & other odds and ends.... My Cardomain |
06-22-2007, 10:47 PM | #216 | ||
You assume correctly! I'll get to the blazer in a few weeks. I did the burb because we are taking a road trip to FLA.
07-03-2007, 03:02 PM | #217 | ||
AF -Advisor
It has to go to the intake, not the oil fill tube. Your setup will do nothing other than impregnate the oil with fuel and raise crackcase pressures. All you did was install a pointless loop.
1995 Factory Blazer Service Manual for sale, PM if interested. |
07-03-2007, 03:07 PM | #218 | |
how many have had less oil burn/usage ????
07-03-2007, 03:11 PM | #219 | ||
Problem?
07-03-2007, 03:12 PM | #220 | ||
AF -Advisor
07-03-2007, 03:31 PM | #221 | ||
AF -Advisor
07-03-2007, 03:38 PM | #222 | ||
07-12-2007, 01:20 PM | #223 | |
How often should one change his pcv valce?
07-12-2007, 01:22 PM | #224 | ||
07-12-2007, 01:32 PM | #225 | ||
AF -Advisor
