Engineering/Technical Ask technical questions about cars. Do you know how a car engine works? |
04-22-2016, 08:25 AM | #1 | |
Should I get a wheel alignment ?
I recently just started to notice that my car is slightly pulling to the left. It's not much. If i let go it will go straight for a few meters before pulling. Not sure if its worth getting it realigned ?
It's an AWD car as well and I checked the tire pressure and make sure the breaks were not sticking. Thanks |
04-22-2016, 03:55 PM | #2 | |
A990 racer
Re: Should I get a wheel alignment ?
Switch to front tires Lt to rt, see what happens.
04-29-2016, 07:21 AM | #3 | ||
As for the op you said realigned have you had I'd done before? I would do like max said rotate front tires side to side. If it started all of a sudden it's more likely slipped belt in a tire. |
05-12-2016, 01:18 PM | #4 | ||
One other thing - in most all-wheel-drive cars, the rear wheel alignment can cause a pull just like the front wheels. When you have your alignment done, make sure that it's a 4-wheel alignment! Best regards, Dave B. |
The Following User Says Thank You to Dave B. For This Useful Post: |
maxwedge (01-11-2017)
05-12-2016, 06:10 PM | #5 | |
A990 racer
Yeah and get a before and after printout.
01-11-2017, 05:43 AM | #6 | |
It is most necessary to do wheel alignment when you found some mistakes in car wheels. Wheel alignment is the option which you can choose if you found that your car tires not rotate properly and car is pulling unnecessarily.
Signature removed by moderator |
01-11-2017, 11:55 AM | #7 | |
A990 racer
What are mistakes in car wheels?
