Go Back   Automotive Forums .com Car Chat > Plymouth > General Discussion
Old 06-16-2018, 12:06 PM   #1
jmridings
Sundance Temperature Gauge.
I have a 1994 Sundance, 2.2 liter engine that the temperature gauge stopped working after I timed the engine. The book says to disconnect the sending unit to time the engine. When I reconnected the sending unit the gauge no longer worked. I replaced the engine sending unit but no change. I also checked all the fuses in the fuse box. There doesn't appear to be any broken wires at the sending unit connection. I recently had Dodge put in a new timing belt but now the car vibrates like all heck. That's why I was checking the timing. Until the dealer did this repair the car was running like a top. Any ideas where to check for this gauge problem? Thanks.
jmridings is offline   Reply With Quote
Old 06-25-2018, 09:06 PM   #2
jmridings
Re: Sundance Temperature Gauge.
Problem fixed. I found a second smaller sending unit between the distributor and the alternator bracket that the wire had fallen off.
