Go Back   Automotive Forums .com Car Chat > Engineering/Technical
Engineering/Technical Ask technical questions about cars. Do you know how a car engine works?
Old 06-23-2002, 05:46 PM   #46
GPrince
1 your not paying for the fuel
2 the abrahams m1a1 uses turbine engine = High power dencity
GPrince is offline   Reply With Quote
Old 06-24-2002, 08:39 PM   #47
454Casull
High power density? Wrong term.
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
454Casull is offline   Reply With Quote
Old 06-24-2002, 10:45 PM   #48
ivymike1031
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
sounds like an appropriate term to me... what was your complaint?
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
ivymike1031 is offline   Reply With Quote
Old 06-25-2002, 10:27 AM   #49
454Casull
My mistake. I thought power density and power-to-weight ratio were different.
..mmustt... get.... of... crraa
Old 07-16-2002, 11:24 AM   #50
Gravitom
Gravitom's Avatar
Just a little clarification
Modern F1 cars use 3L V10s with an extremely short stroke that lets them rev to about 18,000 rpms and produce about 850hp.
Late 80's/Early 90's F1 cars used 1.5L V6 Turbos producing 1500hp. They were eventually banned because they were too fast and getting expensive. But they were wrong and modern V10s cost just as much.
Gravitom is offline   Reply With Quote
Old 07-19-2002, 10:27 AM   #51
Jimbo_Jones
heavier pistons are harder to get moving but have more weight... therefore more torque... whereas, little pistons are easier to get moving but have little weight... therefore more horsepower
3rd Gear Burnouts... Oh Yeah!
Jimbo_Jones is offline   Reply With Quote
Old 07-19-2002, 10:31 AM   #52
Gravitom
Gravitom's Avatar
Does that mean when you put in lighter forged pistons you are actually reducing your torque for more horsepower?
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
Old 07-19-2002, 04:27 PM   #53
texan
Writer Mod
texan's Avatar
No, piston weight has nothing directly to do with power output.
'03 Corvette Z06
'99 Prelude SH
texan is offline   Reply With Quote
Old 07-19-2002, 05:18 PM   #54
SaabJohan
The bore is usually around 92-96 mm and the stroke 42-45 mm, and at 18000 rpm this gives forces in the 8000 G area. The old F1 turbos usually had max rpm at around 12000 and this gives forces in around 5000 G but today the parts like pistons, piston pins and connection rods are lighter. To make them light materials like metal matrix composite and titanium are used, and these materials aren't cheap..
SaabJohan is offline   Reply With Quote
Old 07-19-2002, 09:08 PM   #55
454Casull
You say metal matrix composite; which part[s] use this material? And what is the metal matrix? What is the composite?
Old 07-20-2002, 12:01 AM   #56
ivymike1031
I don't know very much about these mat'ls, so I don't have a whole lot to add to the discussion.
The whole shebang is the composite (metal and all).
Definition I looked up online: Metal Matrix Composites: Materials in which continuous carbon, silicon carbide, or ceramic fibers are embedded in a metallic matrix material.
Try this site for more info on Al-SiC MMCs: http://www.x-lite.com/materials.html#mat
I don't know for sure (and right now I don't feel like searching to find out), but I would guess that in an F1 engine, MMCs are used in the conrods and pistons, but probably not the crankshaft or piston pin. It wouldn't surprise me to find out that you can make an aluminum cylinder wall into a MMC cylinder wall through some special treatment processes. I wonder how well MMCs wear, and how well parts that run against MMCs wear.
Old 07-20-2002, 08:42 AM   #57
SaabJohan
MMC is used in pistons, cylinderliners and possibly also in block and cylinderhead.
http://www.perfectbore.com/motorsport2.htm
Conrods are titanium and the crankshaft is made of steel.
Old 07-20-2002, 09:22 PM   #58
454Casull
MMCC's Al/SiC MMC has a density of 2.9g/cc, while 2618 Al alloy, which is what many racing pistons use, has a density of 2.81g.
Old 07-20-2002, 11:09 PM   #59
ivymike1031
ok... was there a point you were planning to make?
Old 07-20-2002, 11:40 PM   #60
454Casull
No, I'm just wondering why it's used.
