| Latest | 0 Rplys |
11-07-2004, 10:00 PM | #106 | ||
Re: Re: Oil
for perhaps ALL 'civilian' car/truck owners, syn oil brings nothing to the table. when is the last time you have ever heard of 'engine failure due to oil' and 'dodge' wasnt on the nameplate? |
11-07-2004, 11:43 PM | #107 | |
Banned
Re: Oil
I'd say Every time that I see a worn out chevy cam shaft (often) or every time that I see fried bearings in Fords (not quite as often). Synthetic oil helps prevent these things from wearing out.
It seems to me that I see less Dodge engines with problems than either Ford or Chevy... although there aren't that many dodge's around where I live. |
11-08-2004, 01:43 AM | #108 | |
The 70's are over (the last time a soft chevy cam has been encountered) and ford uses such huge greedy oil passages they never lose bearings. As I said, engine failures due to oil just dont happen, even on ones baked to death.
Each engine rebuild I do I return the bearings to the customer to explain what was found. Unless something really bad happened like drove the engine with water in the crank, even bearings worn thru the lead and copper are usually within allowable tolerance and unless metal filings were put in the oil, the cranks are typically good to go for street uses. |
11-08-2004, 04:43 PM | #109 | ||
AF -Advisor
Re: Oil
1995 Factory Blazer Service Manual for sale, PM if interested. |
11-08-2004, 05:21 PM | #110 | |
Banned
Re: Oil
I wish that you could explain my blazers old motor with just 4 years since the last re-build before the cam packed it in... plus the bearings were on their last legs. Although I didn't own it then and I'm not sure how it was taken care of.
11-08-2004, 07:27 PM | #111 | ||
AF -Advisor
Re: Re: Oil
11-08-2004, 08:06 PM | #112 | ||
Re: Re: Oil
But destroying bearings because of LACK of lubrication should go under the 'duhhhhh' category. what did my first post here say? change the oil with manu recommended blah blah blah. |
11-08-2004, 08:33 PM | #113 | |
Re: Oil
Can anyone verify the diesel flush?
Hahahaha BlazerLT and atomicpulse... "It is about people polluting the environment." Since when do Canadians care about the environment? You just truck your trash into michigan anyways... |
11-08-2004, 09:36 PM | #114 | ||
AF -Advisor
Re: Re: Re: Oil
Just out of curiosity, what is the recommended change interval quaddriver?
