Go Back   Automotive Forums .com Car Chat > Jaguar > S-Type
Old 07-13-2006, 07:38 AM   #1
mondeyman
Changing Batteries in Remote Key
Any ideas as to how to replace batteries in my remote key. I can get it into 2 halves, the bit with the key and the bit with the buttons on, but I can't see how to get it apart further to get to the batteries.
Thanks
mondeyman is offline   Reply With Quote
Old 07-13-2006, 08:10 PM   #2
Aston_Jag_Tech
Re: Changing Batteries in Remote Key
What car are the key and fob for? Is the remote(s) the original remote(s). Do they work intermittently? Car year, model would help also. Thanks
-Scott
Aston_Jag_Tech is offline   Reply With Quote
Old 07-14-2006, 02:35 AM   #3
mondeyman
It is for a 1999 S type jaguar original key. Nothing wrong with the key I just want to change the batteries if I only knew how!
Old 07-14-2006, 03:14 AM   #4
Aston_Jag_Tech
I assume you have a seperate key and a seperate key fob(remote) 2 screws to remove or just pry a little screw driver inbetween the lips and open it up.
If you have the integrated key/key fob combo, pry the two plastic pieces apart, you wont break anything. its a snap spring fit.
Hope this helps
-Scott
Old 07-14-2006, 04:24 AM   #5
mondeyman
I have the inegrated key, I can prize the key bit off, so it come in to 2 peices, the bit with the metal key on, and the bit with the remote.
What I can't see is how the remote bit come apart further to replace the batteries.
Old 07-14-2006, 12:02 PM   #6
mondeyman
Sorted!!!!
Old 07-14-2006, 08:47 PM   #7
Aston_Jag_Tech
Thumbs up Re: Changing Batteries in Remote Key
Originally Posted by mondeyman
Sorted!!!!
Did you fix it?
Old 07-15-2006, 03:53 AM   #8
mondeyman
I have indeed, I was in the right area, just wasn't forceful enough with prizing the 2 bits of the case apart. It splits around the central line of the case.
Got to do it again now as I didn't have the right battery yesterday.
Thanks for the help.
Old 07-16-2006, 12:11 AM   #9
Aston_Jag_Tech
Great! Your welcome
