| Latest | 0 Rplys |
WIP - Motorbikes Post topics for any "Works In Progress" motobikes projects in this sub-forum. |
08-18-2011, 12:32 PM | #1 | |
KAWASAKI NINJA ZX-12R - Tamiya 1/12
I build a new model...
It's a Kawasaki Ninja ZX-12 from Tamiya. These are the sets I'm gonna use to build one (a kit, HD's chainset, CM's PE set): I started with engine. Removed all plastic screw/nut heads - I'll replace them on T2M's.Painted with Gunze surfacer: Rebuilt swingarm. I filled it with stipes made from polystyrene sheet. Cut off suspension linkage: I also made holes (using halfround file) for a chain tensioner: A little upgraded clutch cover and filled with Magic Sculp putty air ducts: Now I'm working on engine paintwork and frame assembly... More updates soon Last edited by Mr. Jekyll; 08-18-2011 at 04:07 PM. |
08-24-2011, 05:04 PM | #2 | |
www.hiroboy.com vendor
Re: KAWASAKI NINJA ZX-12R - Tamiya 1/12
Nice start
09-30-2011, 10:33 AM | #3 |
10-01-2011, 06:20 AM | #4 | |
Mr. Jekyll - how did you do the chain sprocket set?? and what did you use?? what is "magic sculpt" who makes it - looking very good so far - Thanks - John
10-29-2011, 04:59 AM | #5 | ||
I use the HD chain set you can see above, first photo
Here's a little progress. Also upgraded radiator: ...and fitting to engine/frame: |
11-05-2011, 12:46 PM | #6 | |
Painted cowlings. Now I have to paint with clear (2K).
12-28-2011, 03:28 AM | #7 | |
I've build a new rear shock:
I prepared the frame and fender to cover with base and black finally. Also made a license plate holder: |
12-28-2011, 08:10 AM | #8 | |
Very clean work on the shock - did you do it all by hand or was there machining tools involved?? like a lathe-mill? All in all this build is really fantastic - John
12-28-2011, 09:56 AM | #9 |
01-17-2012, 11:30 AM | #10 | |
I finished fuel tank and the cover. Added some CF and screws from T2M:
Finished chain set. I washed it little with Tamiya's smoke/black enamel: Completed frame... ... with a ignition module - I made it by myself, there was no with the kit: |
02-26-2012, 12:59 PM | #11 | |
This looks fantastic!
Great work so far |
02-26-2012, 06:24 PM | #12 | |
Wow. Does the zx12r decals on the side cowlings come with the kit? Great progress, keep us posted!!
02-27-2012, 03:06 PM | #13 | |
This looks fantastic! Congratulations
Sandro |
06-04-2012, 03:28 AM | #14 | |
Almost finished engine. I added some wires, cables and hoses. Now, just put into frame
Swingarm with wheel, chainset and brake. I need to add some small details. |
06-04-2012, 02:01 PM | #15 | |
Jekyll - nice attention to detail on the engine with the use of the T2M bolts - also the chain looks pretty good - what color gold did you use and does it have a wash on it? - thanks - John
