Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Interior | Exterior | Appearance
Interior | Exterior | Appearance The place for all interior, exterior and general non-performance modifications.
Old 01-24-2007, 11:48 AM   #1
jiveshucker
2000 Blazer rim question
I purchased a set of rims that do not line up with my lug nut pattern. It is very close however and if the holes were larger, the rims would be able to fit. I am wondering what would happen if I enlarged the lug nut holes on the rims? In what way would this affect my vehicle?
Thanks for the help!
Dana
jiveshucker is offline   Reply With Quote
Old 01-24-2007, 11:54 AM   #2
scoobytuff
Re: 2000 Blazer rim question
Is it just that the lug nut holes dont line up or is there a definite difference in the bolt pattern like say a 1/4". I think you have a 5x4 3/4 bolt pattern. Measure the bolt pattern on the wheels you bought. If the bolt pattern is different you playing with fire messing with the wheels.
scoobytuff is offline   Reply With Quote
Old 01-24-2007, 12:13 PM   #3
jiveshucker
Do you know what kind of effect it can have if I were to drill out the holes? I only spent $100 on the rims and tires. They were from a brand new Mazda SUV and the guy had bought a set of rims to replace the stock 18" rims. They are very nice but at the same time if it didn't work then I would only be out $100. Have you ever seen this done before?
Old 01-24-2007, 01:02 PM   #4
scoobytuff
I think the Mazda bolt pattern is 5x4.5. Not only is the bolt pattern different but if they came off of a Mazda Tribute they have a front wheel drive offset. If you took them to a machine shop they could probaly only elongate the holes. This would make the wheel fit poorly and since your blazer is lugcentric they would cause a bad vibration at speed. The issue of the backspacing would cause you to have to use spacers to clear the brake calipers. You may have better luck with back spacing if your Blazer is 4x4. I seriously think you will have a problem finding a machine shop to do the work(liability reasons). If you do it will probably be expensive. Hope this helps.
Old 01-24-2007, 02:26 PM   #5
jiveshucker
Thanks!
Old 01-27-2007, 05:11 PM   #6
pimprolla112
pimprolla112's Avatar
Send a message via AIM to pimprolla112 Send a message via MSN to pimprolla112
You can also look around for wheel adapters, which will give the correct spacing if its wrong, and also give you the right lug pattern.
Cant remember who posted it but if you see it give yourself credit
Don't ever look at cars as just imports or domestics. Just because a car is made in a certain country doesn't mean that it is anything like another car from that country. An example of this is Mitsubishi reliability, just because they are Japanese doesn't mean that they are as reliable as a Honda or Toyota.
Cardomain
pimprolla112 is offline   Reply With Quote
Old 02-01-2007, 08:08 PM   #7
bell9440
if you want to sell them let me know
bell9440 is offline   Reply With Quote
