Go Back   Automotive Forums .com Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Closed Thread Show Printable Version Show Printable Version | Email this Page Email this Page | Subscription Subscribe to this Thread
Old 09-03-2005, 10:55 PM   #31
DeleriousZ
DeleriousZ's Avatar
Send a message via MSN to DeleriousZ
Re: '86 300zx in need of at least 400hp(stock now)
oh and screw low compression ratio's... i'm switching my z to direct ignition using no spark plugs and upping the cr to 20:1 and running 50 lbs of boost...
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
DeleriousZ is offline
Old 09-03-2005, 11:45 PM   #32
k3smostwanted
Z Cars Fanatic
k3smostwanted's Avatar
Send a message via AIM to k3smostwanted
Re: Re: '86 300zx in need of at least 400hp(stock now)
i think that is physically impossible. there has to be a law of physics against it or something.
boost cooler system? like water/alcohol injection? maybe...Z1 is selling a kit now. maybe get a custom cell made to put in the hatch and hose it to the engine, therefore i dont have to try to find an extra space in the engine bay to put it.
ZedEx Crew Member #4
k3smostwanted is offline
Old 09-03-2005, 11:58 PM   #33
DeleriousZ
DeleriousZ's Avatar
not physically impossible, race tuned diesels do it all the time... just need the metal bits to hold that sort of pressure..
as for the boost cooler thing i think i saw it on amz, and the site is f'd at the moment...
Old 09-04-2005, 02:42 AM   #34
k3smostwanted
Z Cars Fanatic
boost cooler?
Old 09-04-2005, 10:29 AM   #35
longlivetheZ
longlivetheZ's Avatar
Send a message via AIM to longlivetheZ Send a message via MSN to longlivetheZ
Boost cooler? That's what an intercooler is...lol...a boost cooler.
You're gunna run CO2, k3?
Who cares what's in your wallet...what's in your garage?
VG30ET in process of rebuild on left and my 88 300ZX NA, 2 Seater, 5-Speed...my 3rd Z31
Hope you can see the tiny pic...AF reduced the size limit!
Beer is living proof that God loves us and wants us to be happy. --Benjamin Franklin
longlivetheZ is offline
Old 09-04-2005, 11:29 AM   #36
k3smostwanted
Z Cars Fanatic
i think so...cheaper than nitrous and still freezes the intercooler.
i think im going to do 3 different nozzles...probably need 2 tanks.
a nozzle to spray each intercooler and then a nozzle to spray through my oil cooler. my thinking process for the oil cooler one is this...spray the oil cooler it will go trhough the oil cooler in which my radiator fan will suck the C02 through my ac condensor and then through the radiator. so in a sense i could effectively lower the temp of not only my oil but also my coolant.
i was thinking of getting really in depth with it and build a shroud that will connect from my oil cooler to my radiator...so the air has to be pulled through my oil cooler also but using the same fan that my radiator does. or i guess i could just put a very small fan on the back of my oil cooler. we will see...
Old 09-04-2005, 02:18 PM   #37
DeleriousZ
DeleriousZ's Avatar
actually they're technically called charge-air coolers, but whatever...
'boost cooler' is the water/methanol injection kit that injects into your intake tract.... not a bad price and it's a nice security option to have with it installed with a WOT switch...
Old 09-04-2005, 02:51 PM   #38
longlivetheZ
Ah...interesting. Never heard of C02 being used like that. You could use anything cold, in theory...kinda gets me thinking...
Old 09-04-2005, 10:22 PM   #39
k3smostwanted
Z Cars Fanatic
yeah...maybe a little later. i wont need that yet on stock turbos and such. my cooling system will be top of the line...
Old 09-06-2005, 10:51 AM   #40
stephenp
Send a message via AIM to stephenp
i still like the 2 to 1 comp. ratio but go farther do a 1 to 1 compressoin then you could run like 220 psi boost on pump gas.....
ok well anyway on the noite of lowering compression in doing so and allowing for more space to be occupied by the added air you also add more fuel as a result more force to push the piston down
ok increase compressoin so you get 15 to 1 how much hp is that.... probably close to 275hp no boost 275 hp cool
ok tajke a 7.3 to one comp. motor and give it like 15 psi of bost what do you get the same 15 to 1 comp. but what hp......prbably closer to 325.,..... hmmmm what to do what to do
also dont forget what i had meant by lowering compressoin i said clean up the head as in take off all hi9gh spots and unshroud valve remove some of the plug boss(dont forget to apply enough washers to keep the plug just into the chamber
but enough of the mumbo jumbo
get an aftermarket turbo, big inj, fuel pump, ignition system, clean up head, and a 150 wet shot of nitrous
stephenp is offline
Old 10-17-2005, 10:54 PM   #41
llello
if i wonted to do a engine swap to a 86 300zx (non)
which engine would be the best, with the most hp.
and would a z32 twin turbo engine fit in a 86 z31.
llello is offline
Old 10-17-2005, 11:21 PM   #42
DeleriousZ
DeleriousZ's Avatar
*sigh*
yes it would fit... if you have to ask, no, you can't do it yourself... yes a shop would charge most likely 10k+ to do the swap. a better swap would be a vg30et or turbocharging your engine now depending on the condition of it
some other swaps are the rb20det, rb25det, rb26dett, sr20det, random v8, 2jZ... just about anything you can think of really... just gotta antie up the dough...
Old 10-18-2005, 01:57 PM   #43
k3smostwanted
Z Cars Fanatic
yep...i still think the best swap for the Z31 is the RB20DET.
now this thread will be closed, it is way old and i think he answered the questions. if anyone would like to further discuss something pertaining to this thread, reference it and start a new thread.
Closed Thread
