| Latest | 0 Rplys |
Let's get Technical! Discussion for hardcore in-depth motor heads! |
07-03-2005, 01:52 AM | #1 | |
pics of a d16a6 ghetto dizzy on vtec head???
i have a 90 civic dx,did the mpfi swap now im workin on the mini me swap(d16z6 head) on d15 block and d16a6 dizzy,ecu,intake still obd 0..ive done alot of reading online thats says you can use your d16a6 distributor on a d16z6 vtec head,it says you have to grind your distributor down and use washers for it too work.but i cant find any pics on were too do this or were to put the washers and im poor so i cant afford the obd1 conversion yet.can sum1 plz help me out and give me sum pics of how to make the d16a6 distibutor fit on the d16z6 vtec head!!! the swap is done all except that..plz help ~thanx marcus
07-03-2005, 04:31 PM | #2 | |
Re: pics of a d16a6 ghetto dizzy on vtec head???
come on someone must kno were theres a pic of this setup?? or have a digital cam and take a pic of there set up ??? i lined up the d16a6 dizzy with the d16z6 head and only one bolt lines up..where do i drill the wholes or add the washers?? plz sum1 help me out!!! thats all i gotta do then im done with my swap
07-06-2005, 11:21 AM | #3 | ||
Re: Re: pics of a d16a6 ghetto dizzy on vtec head???
07-06-2005, 01:45 PM | #4 | |
Kind of a Big Deal
why dont you use a z6 dizzy?
07-06-2005, 02:19 PM | #5 | ||
07-06-2005, 02:24 PM | #6 | |
Kind of a Big Deal
well what else do you need? i have a bunch of obdI d16z6 stuff for sale.
07-08-2005, 12:18 AM | #7 | ||
07-08-2005, 09:41 AM | #8 | |
Kind of a Big Deal
well, i have the z6 ecu, intake and dizzy still avalible
07-08-2005, 04:42 PM | #9 | ||
07-08-2005, 06:28 PM | #10 | |
Kind of a Big Deal
in MA, and how much do you have, they are just collecting dust so im not pickey (except the ECU)
07-08-2005, 11:37 PM | #11 | ||
07-24-2005, 07:39 AM | #12 | |
listen. take your d16a6 distributor and stick it in the slot in the cam of the z6 head. just as a base setting, turn the distributor towards the firewall until the top bolt hole on the head for the distributor is covered up by the front of the d16a6 distributor. get a timing light and check your ignition timing. set it at 16 BTDC (the middle mark). where the distributor is sitting is where it needs to be. use a little imagination and figure it out for yourself how to cut the distributor to get it to fit where the timing is correct.
07-24-2005, 04:05 PM | #13 | ||
08-02-2005, 11:50 AM | #14 | |
you'll need to remove the parts outlined in black. the distributor should be rotated towards the firewall so that the top bolt is barely holding onto the distributor. |
04-12-2009, 03:44 PM | #15 | |
i have this swap. it works but only back whole lines up. i took a piece of flat aluminum stalk about 3.5 to 4 inches long and drilled a whole in one ened then using the back whole on the dizzy loosely bolt in then cross over the next arm on the base of the dizzy and drill another whole in the stalk then bolt in the top of dizzy. not pretty but it works till u have the money to do it rite
