| Latest | 0 Rplys |
10-22-2007, 07:28 PM | #1 | |
93 rrc electrical
has the 4.2l and eas fully operational
ok so far the problems are rearview mirror not dim, but maplights work sunroof not work interior lights, (courtesy light) drivers seat no move(power at 30a fuse under driverseat, none at switch) cruise power mirrors stereo emergency flashers and now the heater(when i first got it the heater worked, when i put on the high beams it would kick fan to high and i believe the water pump is gone(leaking, could it be just the seal) abs light and traction control lights on in dash(sometimes they are both off, but usually on) hi/lo shifter not shift from hi was told everything was working including the sunroof can anybody help with any of these issues, all help is greatly appreciated ok it seems after the ignition switch the brown power wire doesn't have 12volts in a lot of places, is there a large joint section somewhere in the harness i should check opcorn: or a relay maybe? |
