| Latest | 0 Rplys |
03-08-2012, 01:06 PM | #1 | |
1994 Dodge b150 cargo van-hesitation on gas pedal
I had a major tune up not long ago on my van. I'm noticing now at times when I press on the gas pedal sometimes that it hesitates before kicking in to run normally. Is this a sign of? Fuel pump? Or. I'd like some opinions before it gets worse. Thanks.
03-08-2012, 03:54 PM | #2 | |
Re: 1994 Dodge b150 cargo van-hesitation on gas pedal
It's more likely a sign of a vacuum leak, a bad MAP sensor, or a bad TPS.
03-08-2012, 05:15 PM | #3 | |
Bluezuan, CEL on? Do you use fuel system cleaner regularly? Cleaned the throttle body lately? Could be a sensor also as stated by alloro.
03-09-2012, 09:31 PM | #4 | |
If it's injectors getting clogged, then the B12 Chemtool treatment in the gas tank for four fillups would help clear them up really well. Just toss in one can when the tank is 1/2-full and then drive until the next fill up. Then repeat.
1994 is a strange year. The van could be pre-magnum or a Magnum engine type for the V8. If the engine is a Magnum, then clean the IAC and the two IAC port holes. Do a search on the web for my "How to clean the IAC" It's a step-by-step DIY tutorial.
71 Duster 340, 74 T&C 440-Interceptor, 74 Duster /6 225, 76 Aspen /6 225, 79 Volare S/6 225, 81 Pacer I6 258, 88 Colt I4, 85 Caravan 2.6L, 94 Caravan 3.0L, 96 Caravan 3.3L, 00 Ram Van B1500 3.9L, 01 Ram Van B2500 5.2L, 05 Caravan SXT 3.8L |
The Following User Says Thank You to Mopar_Stev For This Useful Post: |
jamesslcx (03-10-2012)
03-11-2012, 06:16 PM | #5 | |
Thanks for the advice. I'll try the chemtool. See if it helps. Like I said I had my mechanic do a thorough tune up. Including cleaning the fuel injectors. Who knows. Might have gotten some bad gas somewhere along the line,
