05-15-2007, 07:00 PM | #16 | |
Re: Miles to the Gallon on a Dodge Ram
I'm justing waiting for the old 360 to give up the ghost, then its off to find a donor truck to pull a nice 12 valve cummins and tranny out of to swap into the 4x4.
CB Channel 17 Space Ghost '1992 Dodge W-250 Club Cab Long Bed V8 5.9l 4spd H.D Auto 4x4 4.10 Gears '1974 KIT 11' Kamper '1987 Custom Built Pullman Mini Camper (The Pullman Mini Camper Project) '2004 Bi-Mart 1000lbs Cargo Trailer (Chuck wagon) |
05-17-2007, 09:42 AM | #17 | ||
AF - Advisor
1992 Bravada, 201K, stock 1997 Bravada, 101K, stock...was "called away" "Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14 Time to turn so's you don't burn. |
05-18-2007, 06:08 AM | #18 | |
1998 Ram 1500 4x4 gets 13-14mpg w/360 Mag, I have a friend that removed his front shaft and claims to get 19-20mpg same truck.
Docs |
05-20-2007, 01:44 AM | #19 | |
Usually around 17.5mpg highway.
2006 Ram 1500 Quad Cab 4.7. Dave |
05-20-2007, 01:52 PM | #20 | ||
94 ctd 2500, bhaf,4in exhaust, kat missing, 2wd, #10 plate with boost elbow, egt,boost and tranny temp gauges by Hewitt on pillar, gn hitch, and a few more things.. |
05-24-2007, 07:06 PM | #21 | |
What are all the things I can do to get better mileage from my 5.2 stick? I heard Lucas fuel injector cleaner, ...taking off the front shaft??? and being a manual should help, I should keep it in top gear and stay around what mph/rpm on long highways?
Would a cold air intake help?
1996 Dodge Ram 1500 5.2L 5spd!!! 1987 Chevy Iroc-Z- -Needs a new cat 1992 Nissan 240sx 5spd- SOLD |
05-24-2007, 07:30 PM | #22 | |
If you get a cold air you also need to get an exhaust. More air in needs a way out as well. I got a stick as well and get lately 12-14 city and 17 highway. The typical rpm range is 1500-2000 for best gas mileage.
06-10-2007, 12:00 PM | #23 | |
all I know is these dodge rams are GAS Guzzlers. The fuel MPG seems to vary all the time depending on the way you drive? the best MPG I get is driving from california to utah on flat highway in cruise control. BUT when we drive it hard and drive it up hills. IT eats everything up fast.
Right now gas is about $3.75 a gallon. We fill up at COSTCO because its $.20 cheaper. It cost about $81 to fill the entire tank up. The tank last about 2 to 3 days because we use it every single day. We have 270,000 miles on a gas motor with its 2nd tranny on it. This is the 360 5.9L v8 |
06-15-2007, 04:11 PM | #24 | |
My 2001 3500 Quad cab with a cummings turbo diesel gets over 18 mpg. around town and well over 20 on the highway.
06-16-2007, 12:22 AM | #25 | ||
Cummins not cummings
06-22-2007, 10:06 PM | #26 | |
I just bought a 2005 1500 ram with the hemi. Does a k&N cold air filter give you better gas milage or just better performance. I have friends with ford 250's who have changed chips it doesn't void the warranty and gives you better milage. Anybody know anything about that for a dodge.
