Go Back   Automotive Forums .com Car Chat > Jeep > Cherokee
Old 03-31-2016, 09:04 PM   #1
reese88
1996 jeep cherokee lighting problem
Hi, my 1996 jeep cherokee is having a problem with the lights when I pull the plunger switch my dashboard blinker lights and high beam light come on but none of my outside lights come on besides my tail lights.
reese88 is offline   Reply With Quote
Old 04-01-2016, 08:10 AM   #2
rhandwor
Re: 1996 jeep cherokee lighting problem
http://www.ebay.com/ Item 281937147925
Pull out switch and check the power to the switch.
Check power coming to switch then power leaving switch.
rhandwor is offline   Reply With Quote
Old 05-13-2016, 01:32 AM   #3
thinmints
i have the same issue, the side marker lights will occasionally start working again but only for a few days or hours, you probably have a wire that has gotten brittle over the years, trying to find it is not easy, if you find a solution be sure to post other wise id just live with it
thinmints is offline   Reply With Quote
Old 05-13-2016, 06:58 AM   #4
peter123wallace
It's not that easy to live with it though...
peter123wallace is offline   Reply With Quote
Old 05-13-2016, 10:34 AM   #5
fredjacksonsan
Caution: Monkeys bite!
fredjacksonsan's Avatar
Send a message via AIM to fredjacksonsan
There's either a short or the switch itself has gone bad. I agree with replacing the switch first.
Also, I had a Grand Cherokee that acted oddly due to a corroded battery cable not sending enough juice; you may want to check the condition of your battery cables (and battery, while you are at it) to make sure that's in good order.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
fredjacksonsan is offline   Reply With Quote
