Old 12-02-2020, 10:20 AM   #241
Scale-Master
Scale-Master's Avatar
Re: Lola T-70 Mk III
More little machined aluminum hardware added to the (3D created) rear cover.
Scale-Master is offline   Reply With Quote
Old 12-03-2020, 10:10 AM   #242
Scale-Master
Dry fitting the transaxle subassembly together…
Old 12-03-2020, 01:17 PM   #243
sky1911
sky1911's Avatar
Not many comments here. I think that's because we're in awe - well I am anyway. The combination of designing and printing / growing the parts, machining other parts etc. is just beautiful.
Just seeing that machined breather can and knowing its scale size since I've got the T70 kit as well is mind boggling.
There is one question I have regarding the engine block. How did you create the crinkeled look? It almost looks like the surface would be flat but there is some powder sprinkled on it that has then been covered with paint.
Top work. After watching the 7 come to life, I'm enjoying every step of this build very much
sky1911 is offline   Reply With Quote
Old 12-03-2020, 05:27 PM   #244
kans0002
kans0002's Avatar
Ditto!
kans0002 is offline   Reply With Quote
Old 12-04-2020, 09:26 AM   #245
Scale-Master
Thank You guys!
You're correct sky1911, the texture is talcum powder. The last coat of paint softens the texture and leaves a gloss finish, a lot like the way painted sand-cast parts look.
Old 12-04-2020, 09:27 AM   #246
Scale-Master
I started texturing and coloring some of the suspension parts…
Old 12-05-2020, 10:01 AM   #247
Scale-Master
I turned my attention back to the interior and started fabricating the dash parts. The bulkhead is all styrene; solid stock and sheet.
The dash/gauge panels were made from sheet styrene too.
A little more styrene was used for the steering column and its mount.
Old 12-06-2020, 10:30 AM   #248
Scale-Master
The tub and some of the other bulkheads and related parts finally received some paint.
Old 12-07-2020, 11:29 AM   #249
Scale-Master
I fabricated the front sway bar guides from brass and styrene and then after machining the bolts and washers I lost one of the guides. I wasn't in the mood to make the same exact part again, so I machined a different style of new (beefier) guides and used the aluminum hardware on them. (I did not find the missing part yet…)
Old 12-08-2020, 10:39 AM   #250
Scale-Master
I permanently installed the rear bulkhead and engine mount cross-member and just had to test fit the block and trans…
Figured I'd do the rear sway bar while I was working on the front one too.
Old 12-09-2020, 06:30 PM   #251
Scale-Master
I made the rear hanger brackets for the exhaust.
Old 12-09-2020, 06:35 PM   #252
Scale-Master
Since it's for the street I started making a crossflow muffler. It would still be loud, but at least not straight-pipe loud.
Inlet and outlets are brass tubing.
Old 12-11-2020, 10:01 AM   #253
Scale-Master
Old 12-11-2020, 10:02 AM   #254
Scale-Master
This is the main muffler bracket/mount. Hand formed sheet aluminum.
And with the mounting hardware…
Old 12-12-2020, 10:38 AM   #255
Scale-Master
But wait, there's more… I embossed the Dynomax logo too.
