| Latest | 0 Rplys |
02-02-2011, 01:06 PM | #121 | ||
Re: just wont run right!!!!! 2001 cylinder 4 misfire
The DTC's will tell you the valves on which cylinder! P0305,P0306,P0307, and P0308. If it's just #7 isolate the injector wire, and cop connector going to that cylinder. |
02-02-2011, 03:29 PM | #122 | |
How many times do you guys let the compression hit the meter?
Briefly I got, 1=190 2=195 3=180 4=185 5=190 6=195 7=180 8=190
Dennis 2003 Mach 1 2008 Expedition King Ranch 4x4 2010 Taurus Limited |
02-02-2011, 05:13 PM | #123 | |
02-02-2011, 05:36 PM | #124 | |
Hey!
The compression looks good, so it may just be a rattle in the secondary cam chain tensioner. What's the deal with alum tape on your Air tube from the valve cover to your Air duct work? Unmetered air will cause problems! |
02-02-2011, 06:48 PM | #125 | |
Yea, Im going to order the secondary tensioners.
Im thinking these. http://cgi.ebay.com/ebaymotors/ws/eB...m=350312408299 Dont suppose auto parts stores have them.
02-02-2011, 06:56 PM | #126 | |
Don't forget to get new spark plug boss seals and valve cover gaskets.
02-02-2011, 07:03 PM | #127 |
AF Premium User
02-02-2011, 07:50 PM | #128 | ||
Last time it was 700 bucks for dealer to do them. I really dread the drivers side with all the hoses. Will take pics as the job goes. Just hope I dont find more problems with the primaries and chains.
02-02-2011, 07:57 PM | #129 | |
1) When you do this job, leave the primary cam to crank timing alone.
2) Lift the secondary cam without losing cam to cam timing and sneak the new secondary cam chain tensioner in. |
02-03-2011, 07:58 AM | #130 | |
Gotcha. Secondary cam only.
Whats the premium valve cover gaskets to get, and where? The parts stores are showing Felpros.
02-03-2011, 01:06 PM | #131 | |
I got mine from http://www.autopartswarehouse.com , they were Felpro.
This car doesn't have an EGR valve, so that's one less problem. I still don't think that Aluminum tape around the Air tube from the Air Intake duct work going to the valve cover might be giving a lean/rich condition, because of unmetered air leaks. |
02-03-2011, 05:37 PM | #132 | ||
02-10-2011, 08:13 PM | #133 | |
Well.................found the noise.
And let me say what a pain in the to get down to the right valve cover. Lets just say the garage last Saturday was not a happy place. And one damn screw in particular! As you diy'ers can see, the tensioner lost its upper slide. Notice where the chain started to eat into the block.
02-10-2011, 08:26 PM | #134 | ||
Oh btw, whats the recommended torque on the cam bolts?
02-10-2011, 08:59 PM | #135 | ||
Caution - 1) Put some clean shop towels in the timing chain cover, so you don't lose any bolts, or nuts. 2) Get a torgue wrench, and check the bottom cam bolts for torgue befor removing. 3) Remove all the bolts on the lower cam. 4) Remove the bolts holding the secondary cam chain tensioner. 5) Lift the lower cam and keep a little tension on secondary chain, so you don't lose the cam to cam timing. 6) Remove the old secondary cam chain tensioner, and slide the new one in. 7) Put the lower cam back in. 8) Torque the bolts for the tensioner. 9) Torque the bolts for the secondary cam. I'am sorry about torque specs, because my http://www.alldata.com has expired. LOL - You should do a AF - YouTube video for this procedure, it usually takes me 2 1/2hrs. |
