| Latest | 0 Rplys |
06-07-2011, 05:47 PM | #1 | |
Need Info On Big Blocks
im putting a 632 (the biggest crate engine available) in my 71 carlo. what else do i need to replace so that they can take the power of the 632? im really lost when it comes to anything outside of the cylinder heads, crank case, and block.
thanks, casey |
06-08-2011, 11:11 AM | #2 | |
Re: Need Info On Big Blocks
You will have to upgrade the transmission , rear end , and suspension with something strong enough to withstand the power the new engine will be producing . Even more important are the brakes and I can't emphasize this enough - they must be upgraded so your stopping power will match your Go power ! This is a very important for your safety and should not be overlooked ! Your frame should be inspected ( it is 40 yrs. old ) for any damage or cracks . Any found should be repaired. Good luck and keep us updated !
" Sometimes I grow so tired " |
The Following User Says Thank You to oldblu65 For This Useful Post: |
PonyTamer (06-08-2011)
06-08-2011, 11:44 AM | #3 | ||
one more question. if its only going to be drag raced and not a daily driver, would i need to do the brakes and suspension? thanks so much |
06-09-2011, 06:15 AM | #4 | |
If you are going to just drag race then brakes, frame, and suspension are even more important. I have seen people go off the end of a track. Make things scarier we have a track up here that used to have a forest of trees after the track. If you are not sure about what you need I suggest you hire a shop with race experience for the frame and suspension part of it. No doubt you will have to convert to a 4 link set up to keep it straight on the track.
