| Latest | 0 Rplys |
09-07-2006, 07:29 AM | #16 | |
Lactose the Intolerant
Re: 92 Accord Transmission Problem
Hey, if you can access the shift solenoids from the outside, try this...give them a few sharp taps with a plastic hammer or something similar...if one's stuck open like I'm thinking, it MAY drop back to rest postion, and you'd have all your gears, even if just until it hung again, but you'd be 100% certain that was the problem...even if not, I'm about 95% it is...
09-07-2006, 07:30 AM | #17 | |
Or if they are the same part number, switch their positions (swap them) and see if the other two gears are affected...that'd prove the theory also...or it may unstick in the process of being moved, and start working right, as per above..
09-12-2006, 09:52 PM | #18 | |
I just had this same problem over the summer. My 1992 Honda Accord Ex had its D4 light stay on too. Affected the Rpms also. So i searched online everywhere looking for an answer. I saw a suggestion from someone that had the same problem to just take off the postive cable to the battery, and put it back on. According to this guy, it fixed his problem. So I tried it and it did indeed work. That was back in June and the problem has yet to return. Think it just reset a bad code in the computer. That was the theory. Car drives perfectly fine.
08-25-2014, 06:01 PM | #19 | |
Ok I have a 92 accord ex its got the 02d1 tcu in it it only has second and fourth. Im pretty sure its the capacitor and resistor but there is no sign of damage do you know the numbers to the ones that are prone to leaking and burning up? I kno on come its r41 or 42 and c28 but idk about this one
