03-06-2005, 05:03 PM | #1 | |
350 crate engine
hey guys, i found a 350 small block shevy for cheap and was wondering if it is possible to do or if it will even fit. If so what type of space will i be dealing with inside the engine compartment and what mods do i have to do.
03-07-2005, 07:56 PM | #2 | |
I've seen it done with a small block ford, and it was pretty cramped. I figure a small block chevy would fit, but you might need a shoe horn and some anal lube. Actually you'd need some really good fabrication skills, because puuting that much torque in one of those cars would probably rip it apart if it was not mounted right and if the car was not strengthened properly.
06-29-2005, 11:55 PM | #3 | |
Re: 350 crate engine
more motor than car the car wieghts like 2000 stock.....man i would like to drive it
07-19-2005, 03:45 PM | #4 | ||
Re: Re: 350 crate engine
http://britishv8.org/swaps/510v8.htm Shot: The owner can be emailed from the site... Good luck...
Regards, Nobody can break it better than me. 88 I4 Slushie, 89 I4 5Sp, 89 V6 5Sp, 82 Corolla, 72 510, 88 Minitruck. |
07-31-2005, 10:30 AM | #5 | ||
Re: Re: Re: 350 crate engine
I have seen a 283 V8 in a 510. With the old style "ram's horn" exhaust manifolds it can be made to fit. But it is super tight. If you haven't bought the engine yet, better to start with a 302 Ford. And FWIW, an SR20DET can make similar power for half the weight.
Drive A Datsun, Then Decide. |
08-02-2005, 10:21 PM | #6 | ||
Re: Re: Re: Re: 350 crate engine
This is why the SR20DET is the swap of choice...
