Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 02-06-2014, 11:13 AM   #16
Wags391
10-year Owner
Re: Oil filter adapter leak at engine
So it turns out the gasket/o-ring kit from Dorman just doesn't work. I bought a Felpro set and did some measuring and with the specs from the Dorman kit, it's plain to see that it would never work. The steel gasket is too thick and the o-ring too thin. I put the Felpro kit on and torqued to spec and success. Felpro from now on. It also only comes with what you need, not multiple o-rings that are close to the same size to confuse you. Luckily the store took back the Dorman.
Wags391 is offline   Reply With Quote
Old 02-06-2014, 11:32 AM   #17
rhandwor
I'm glad you got it fixed. You had a rough time.
rhandwor is offline   Reply With Quote
Old 02-06-2014, 12:58 PM   #18
Wags391
10-year Owner
Thanks. Of course, the lesson here is to stay away from Dorman when possible.
Old 02-06-2014, 04:34 PM   #19
j cAT
these things can happen with the Chinese crap being made. the store took care of it and with your feed back, this will help others , with these leak issues in this area.. I stated before that many had problems with the repair of these leaks.
j cAT is offline   Reply With Quote
