Go Back   Automotive Forums .com Car Chat > Car Audio
Old 11-15-2006, 02:52 PM   #16
bjboertje
bjboertje's Avatar
Re: single amp vs. dual amps
Originally Posted by sickcallawayc12
sell the sony amp, buy two good name brand amps from ebay and make sure they're not sony.
find something that works whether you get one or two (i recommend the latter).
he did.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Rainbow CMX 265 front stage
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
bjboertje is offline   Reply With Quote
Old 11-15-2006, 07:36 PM   #17
Tonglebeak
So am I screwed? Isn't there a way I can put on some kind of 4-ohm resistor so the amp can see a 2-ohm load and pump all 350watts to the sub?
1988 Oldsmobile Cutlass Ciera 2.8L V6
Tonglebeak is offline   Reply With Quote
Old 11-15-2006, 07:55 PM   #18
bjboertje
bjboertje's Avatar
no, you just cant get more than 200 rms out of the amps. adding a resistor will not give more power to the subs.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 11-15-2006, 08:17 PM   #19
Tonglebeak
But isn't this just a matter of getting the amps to see a 2-ohm load?
What if I ran two sets of speaker wire to the sub: 2 positive wires to the same positive terminal, and two negative wires to the same negative terminal on the sub?
I am just trying to find _some_ way to pump out the power I was led to believe I could put out >
Old 11-16-2006, 09:52 AM   #20
PaulD
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
If you put a 4 ohm resistor in parallel with a speaker, the amp will see a 2 ohm load .... unfortunately the resistor will soak up all the extra power your amp will generate. So then your amp will have to push twice as hard to give the speakers the same power as it did without the resistor.
PaulD is offline   Reply With Quote
Old 11-16-2006, 10:48 AM   #21
Tonglebeak
Maybe I should just sell the subs back onto ebay and try to find dvc ones?
I'll wait for tax refund before I mess with it anymore, I'll just live with what I have.
One more question before I end this fight: is there anyway to force the amp to push out more than 200 RMS with the 4-ohm load? Right now the amps run _cold_, so I would think there's plenty, I mean plenty, of room to try to push out more power. Now I'm thinking in terms of overclocking a computer >_>
Old 11-16-2006, 11:33 AM   #22
sickcallawayc12
sickcallawayc12's Avatar
Originally Posted by bjboertje
he did.
he didn't have to listen to me, although he said it sounds awesome and the profiles don't get even warm and it sounds like he plans to get rid of those crappy sony subs down the road anyway so problem solved for now.
1998 Chevrolet Blazer LT (95% stock)
Pioneer AVH-P7500 DVD receiver
12" Alpine Type-R in a sealed box
PIAA Super Plasmas GT-X bulbs
PIAA Xtreme White bulbs
K & N drop-in filter
"Melo" and "AI". Enough said.
sickcallawayc12 is offline   Reply With Quote
Old 11-16-2006, 01:50 PM   #23
PlayStation3
you can get the amp to push more but just not with those subs. and there is no way to "overclock" your amp unless he is made to go lower then 1 ohm
PlayStation3 is offline   Reply With Quote
Old 11-17-2006, 02:52 PM   #24
bjboertje
bjboertje's Avatar
I know, but when you sugguest somthing and no one says there is a better way he will probably listen. I agree the profiles are a good amp for the price, but he could have done better. Problem solved for now, but wasted money in the future.
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 12-03-2006, 08:42 PM   #25
Tonglebeak
I realize this thread got a tad old, but I figured it's better to bump this since it already has the background info.
I found these subs from Pioneer:
http://www.pioneerelectronics.com/pn...tailsComponent
400W RMS, DVC.
Do these look like good subs to use, since I should be able to wire them in parallel and pull 350W RMS from each amp?
Old 12-04-2006, 12:54 PM   #26
bjboertje
bjboertje's Avatar
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 12-04-2006, 12:55 PM   #27
bjboertje
bjboertje's Avatar
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
