Go Back   Automotive Forums .com Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 05-22-2005, 07:28 PM   #1
18sHonda
Send a message via AIM to 18sHonda
Whats the widest tire I can run?
K so I went to NTB Today to buy a new set of back tires for the Z and I fell in love with these G-Force 255 width tire's and the guy was like they can fit then he asked another guy and he said they wouldnt fit no way. But I am seriously questioned by this cause I belive they will. Anyone know for sure if they will or if I need spacers?
I dont drive anything with less that 3 pedals.
18sHonda is offline   Reply With Quote
Old 05-22-2005, 07:34 PM   #2
k3smostwanted
Z Cars Fanatic
k3smostwanted's Avatar
Send a message via AIM to k3smostwanted
Re: Whats the widest tire I can run?
i have 225/50/ZR16's all the way around on my Z32....
that guy doesnt know what he is takling about.
EDIT: whoops, i miss read that post.
ZedEx Crew Member #4
k3smostwanted is offline   Reply With Quote
Old 05-22-2005, 07:55 PM   #3
DeleriousZ
DeleriousZ's Avatar
Send a message via MSN to DeleriousZ
all depends on the offset, what end of the car they're going on, and what z you have. z32's can support up to a 9.5" front and 10.5" rear rim (that's rim size, not tire size, i'm sure the tires are anywhere from half inch to an inch wider) and i'm not sure about the z31. it all depends on offset tho, if you're running a tire much wider than stock you'll want to have it so the tire isn't sticking out much more on one side compared to the other on the front. same with the rear, but you can have a little more sticking out the outside if you want... gives it a slightly more agressive look, and you don't have to worry about rubbing the fenders as long as the car isn't lowered too far...
long story short, 255's should fit no problem
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
DeleriousZ is offline   Reply With Quote
Old 05-22-2005, 08:16 PM   #4
k3smostwanted
Z Cars Fanatic
if we are talking stock N/A wheels here...i dont think your getting 255's on. my 225's on my Z32 overlap like crazy but i dont really know how those tire configuations work.
i have 225's on my stock N/A wheels and i had 275's on my 9.5" wheels...if i remember correctly the N/A's are 7.5" wide. so 255's should correspond with about a 8.5" wheel but like delerious said, its not that easy.
Old 05-22-2005, 09:10 PM   #5
18sHonda
Yeah these are going on the Rear end of my Z32 N/A and on a stock rim. Im just keeping them stock cause im gonna powder coat black..but Yeah you had 275's?? thats f'in huge I was looking at those today its bigger than a corvette tire. How could you fit a 275 and I cant even fit a 255...
Old 05-22-2005, 10:08 PM   #6
DeleriousZ
DeleriousZ's Avatar
he used to have 19"s on there.. they were, as he said, 9.5" wide (not stock) so that's why he could have such a wider tire on the rim. as for you, it wouldn't be wise to go past 235-245 on the stock rim.
Old 05-22-2005, 11:00 PM   #7
18sHonda
what if i got spacers? could I then? Cause I really dont like the 235 the 245 I could live with its just they had some Goodyear G-Force's 255 for 91.00 each. and thats the only width they had that price in.
Old 05-23-2005, 01:34 AM   #8
DeleriousZ
DeleriousZ's Avatar
spacers have nothing to do with it... it's the width of the rim compared to the width of the tire... you can only go so much wider before you start to have problems with sidewall strength
Old 05-23-2005, 07:11 AM   #9
k3smostwanted
Z Cars Fanatic
yeah, the only thing spacers do is, in a sense, change the offset of the wheels. when sizing tires, it has nothing to do with space, the only reference you need is what the overall circumference is of the stock vehicle (this keeps your speedo accurate) and the size of the wheel.
im telling you, once you get a decent size tire on there it will look wider than you think...my 225's looks like a hefty piece of tire when you look at it from the front or back. and the overlap makes it look even more aggressive. i could only imagine what 235 or 245's would look like.
255's wont do you an ounce of good when you go to take a corner and that sidewall crinkles on you...that wouldnt not be good.
Old 05-23-2005, 07:29 AM   #10
18sHonda
ok guys thanks for the info i'll go 245 then!
Old 05-23-2005, 01:17 PM   #11
Bdetore
Also remember that the more rubber you put on the road the harder the engine has to work to turn it. There is a line where the width of the tire and the handling you can achieve goes past each other. If you are doing it just to look cool and you don't care about the performance, no biggie, but remember, you may be sacrificing a few things for the view.
Bdetore is offline   Reply With Quote
Old 05-27-2005, 08:07 PM   #12
Hodo
widest tire depends on your rim size. heres a little chart I live by.
7.5 rim - tire size= 215-225 (you can push to 235 not recomended)
8.5 rim- tire size= 235-255
9.5 - tire size= 265-285
10.5 - tire size= 295-325
And the largest rim tire size I have seen on the street has been a 11.5 rim, 345 tire size. but that was on a Ford GT, and on the Aston Martin DB9.
Finaly got pics of my car....... after I washed it of course.
Hodo is offline   Reply With Quote
