| Latest | 0 Rplys |
07-06-2003, 05:30 PM | #1 | |
lowering 2003 honda civic
I have a 2003 Honda Civic EX that we are going to lower. I want to lower it about 2 inches and put new rims and tires on it. Can anyone tell me anything about lowering this type of car. Also, which would you suggest to be the better or any info on Eibach or Neuspeed lowering kits? Thanks for any replies I get.
07-06-2003, 06:15 PM | #2 | |
Cali Guy
I don't hear much on lowering of 7th gen ('01-'03) Civics, but I see them around all over. The McPherson strut design of the car limits it to my understanding. But Eibach and Neuspeed DO both make kits for it, and are respected brands as well. Also if you can afford it, look into a true full coilover kit such as Tein. Good luck with it.
And welcome to AF.com forums!
Silver '00 Civic EJ6 Coupe PureHonda original member since Feb. 2000 D-series revolution For pics of my baby, click here! All rights reserved... All BITERS served! "The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket." i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift hessemer69 on AIM |
07-06-2003, 09:25 PM | #3 | |
Click here to see what Tire Rack carries for your car I dont know if anyone makes springs that will lower your car 2" Eibach over the Neuspeeds Dont waste your money on cheap adjustable coil-over sleeve springs, if you want coil-over get the fully adjustable kit(spring/shock) like Tein or H&R also replace the shocks/struts when you add lowering springs |
07-10-2003, 09:52 AM | #4 | |
Neuspeed makes springs to lower your car 2-2.25" But if you go that route I would also replace the struts
07-10-2003, 02:00 PM | #5 | |
I've got an '02 si and I've been wondering about this same stuff.
If you lower it, do you really have to replace all the shocks and struts? how much does lowering your car a couple inches affect your handling?
I wasn't born with enough middle fingers |
07-10-2003, 03:21 PM | #6 | |
One more question.. 17" rims look way better than the stock 15's, but is there any advantage to it? seems like it would just slow you down.
I'm more interested in driving the car than looking at it.
07-10-2003, 04:02 PM | #7 | ||
Yes you should replace the shocks/struts(same thing different terms) when you lower the car. Lowering a couple inches with shitty springs is worthless for handling. Invest into performance shocks/springs if want handling or your best bet is a fully adjustable coil-over kit! $$$$$ like H&R or Tein |
07-10-2003, 05:03 PM | #8 | |
I think what you're telling me is "go big or go home".
07-10-2003, 05:35 PM | #9 | |
Just take a blow torch to your springs. That will lower the car.
07-10-2003, 06:54 PM | #10 | |
But won't that ruin it?
07-10-2003, 11:50 PM | #11 | |
I dont recommend heating the springs. It works if done correctly, if not then you have a some ruined springs. The springs get weaker during the process, bouncy, & may or will crack.
07-11-2003, 10:27 AM | #12 | |
People actually do that? I thought it was just a joke.
07-11-2003, 08:03 PM | #13 | |
some people heat them or even cut them down. Do it right replace them with the proper parts, dont be a hack.
07-13-2003, 09:56 PM | #14 | |
When looking at the H&R kits i was wondering whats the difference between cup kits and coilover kits. Is one jsut geared more toward performance and handling while the other is ride quality?
Also if i went with and adjustable set-up would i need to get a re-alignment every time I brought it up or down?
-There he goes. One of God's own prototypes. Some kind of high powered mutant never even considered for mass production. Too weird to live, and too rare to die. -With a bit of luck, his life was ruined forever. Always thinking that just behind some narrow door in all of his favorite bars, men in red woolen shirts are getting incredible kicks from things he'll never know. |
07-14-2003, 12:04 AM | #15 | |
The H&R cup kit is your normal spring & shock set-up. Only these are designed to work with each other. Great set-up, shocks are valved matched to the springs.
The H&R Coil over kit is a fully adjustable coil-over sping/shock package. Right height can be adjusted or spring rates for performance reasons. These are true coilovers that have threaded struts with springs, unlike cheap sleeve coilover that have a threaded collar that fit between the sping/shock & dont work together to well. Both kits are great for performace, the coilover is more for racing than street use. Yes you should align your car after each adjustment & will need a camber kit to get the most out of the coilover kit. Only camber will change, so you will want to mark it some how so you dont have to pay some one each time. Scribe marks. |
