| Latest | 0 Rplys |
03-23-2009, 10:23 PM | #16 | ||
Re: 98 3.8L upper intake designed to fail
From what I have read here, you should change the coolant at LEAST EVERY 3 years. In the mean time, keep an eye on the coolant level.. Al
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip, 1989 Mustang LX 5.0 5sp convertible 1992 Camry LE 2.2 1996 Suzuki RMX250 I'm a victim of circumstance [ |
03-24-2009, 08:32 AM | #17 | ||
this is a crack that forms as the EGR heat causes the poorly designed plastic to fail... the reason I posted this is ,,,,,If you do have a bad intake gasket problem upper/lower replace the upper intake as well....because its gonna fail... this vehicle has never had any gasket problems ....I maintained the coolant system and their is no corrosion..... on your vehicle since it is now old the damage is done,,, if you have not used distilled water and kept the ratio of dexcool to water correct....I use 66% dexcool to 33% distilled water.... |
03-02-2010, 12:06 PM | #18 | |
i have a 99 monte z34 with 300,000 kms& i have never had a problem with the upper intake at all. but the brakes are pretty aweful if you ask me.
03-18-2010, 10:12 AM | #19 |
03-18-2010, 04:33 PM | #20 | |
The rotors tend to worp & bend very easily which makes the pads wear quick. Take my advice don`t go cheap when it comes to brake cuz they won`t last. When you do upgrade the brake you will not have any problems.
03-19-2010, 10:19 AM | #21 | ||
all parts have lifetime warrantee...any failure just bring in the pads/rotors and no cost for you ! |
