| Latest | 0 Rplys |
04-03-2013, 01:48 PM | #31 | ||
Re: Battery Drain problem
Now for the testing. I have been giving you some erronous information. The battery will go down with the alt disconnected completely. I believe the state of the battery charge was confusing me. 1. With battery fully charged, I have a 1.77 amp draw at the battery. 2. Upper fuse block under hood: Left I/P (Left fuse battery) pulls .52 amps. RT I/P (Right fuse battery) pulls .06 amps. 3. Lower fuse block under hood: RT I/P (Rear Defroster/Radio system) pulls 1.19 amps. 4. Drivers side dash fuse block: CLSTR BCB (Body Control Module Cluster/Ignition) pulls .52 amps. 5. Passenger side dash fuse block: Radio (Radio anplifier) pulls 1.19 amps. PWR Drop (Accomadated Device) pulls .06 amps. These are the only ones that have draw. I have driven the car with this problem and everything seems to work fine except for the battery drain. The alternator not working has not changed the anp draw. I hope all this makes sense to you. Thanks again. |
04-03-2013, 02:59 PM | #32 | ||
orange wire 12 volts and the red wire should have some voltage on it to turn on the alternator my guess is 5 volts. |
04-03-2013, 04:59 PM | #33 | |
[quote=j cAT;7034459]lets go thru this one issue at a time . what is the voltage at the /across the battery with the engine running and everything connected including the connector at the rear of the alternator ?
orange wire 12 volts and the red wire should have some voltage on it to turn on the alternator my guess is 5 volts.[/quote Engine running & everything connected: 11.61 volts at battery (Lights are on) Engine dead: 12.00 volts at battery. 12.00 volts at orange wire on alt plug. o volts at red wire on alt plug. Engine running & alt plug disconnected: 11.61 volts at orange wire on alt plug. 5.04 volts at red wire on alt plug. Update: I found the problem with the alternator. It was the connector plug. Somehow it just wasn't making connection. I've narrowed the battery drain down to the radio fuse. Fuse pulled, theres no drain. Radio and disc seems to work fine. Not sure what next step should be. Do you know if there is a particular module that might create this problem? Thank you. Last edited by vanharlin; 04-06-2013 at 07:27 AM. Reason: update |
04-07-2013, 07:49 AM | #34 | |
so the connector plug was the reason the alternator was not charging. this does occur in the rust belt with the conn pins getting corroded.
so now the battery drain is because the radio equipment is not shutting down . this is the BCM issue I stated earlier with other owners that had this mysterious drain. the BCM is a secret device that only the GM dealer can program , that is at a greater expense then what would be if a repair shop could handle it. could be the audio amp portion of the radio system is not being turned off. post back any further info with this issue . |
04-07-2013, 09:51 AM | #35 | |
A battery drain going on 3 pages, is the result of misinformation and making mistakes in testing.....not blaming you, but it illustrates why electrical problems can be costly in a shop.....if you get a bad reading that sends you in the wrong direction, it's time consuming.....
Tracing circuits can be a problem......but thankfully, you have narrowed it down to the radio fuse.....the next move, is to find EVERYTHING that radio fuse feeds.....a wiring diagram is needed......sometimes your owner's manual will list the circuits of each fuse.....thus you can disconnect circuits that are fed by that fuse to find which circuit is causing the draw.... |
04-12-2013, 05:26 PM | #36 | ||
04-13-2013, 08:29 AM | #37 | ||
attach the jumper fuse power input to the power feed side of the fuse socket that has 12volts to it with the key on. they have this at most auto stores. BCM can be expensive.. and will require programing |
04-13-2013, 05:40 PM | #38 | |
j cAT, I don't think this has anything to do with the BCM.....I think the radio fuse, is fed by a 60 amp IP fuse, which is bussed to the battery.....
So if that radio fuse circuit breaks off to more circuits, like an amplifier, that has to be checked out..... I do like your Idea of using an ignition powered circuit ....that will eliminate the draw with the key off.....the circuit has to be able to handle radio current plus what it is already feeding(or you tap into a large current circuit and protect it with a 15 a fuse)..... |
04-13-2013, 05:49 PM | #39 | ||
the BCM has been reported by others that this was the cause of the mysterious drain. I guess when the key is turned off the radio stays on until the door is opened. then the radio should shut down . the switched ignition feed being tapped is of a large current capacity. power windows / ac system / etc.... |
04-19-2013, 10:58 AM | #40 | ||
04-19-2013, 11:08 AM | #41 | ||
04-19-2013, 04:07 PM | #42 | ||
http://shop.advanceautoparts.com/web...archTerm=fuse+ |
