| Latest | 0 Rplys |
View Poll Results: change lube in tranny? | |||
would change lube | 51 | 91.07% | |
would not change lube | 5 | 8.93% | |
Voters: 56. You may not vote on this poll |
01-24-2006, 03:10 PM | #16 | |
Re: tranny oil change?
Regular pan drains / filter replacements and flushes have kept my 4L80E happy for 307,000 miles and still as smooth as can be.
1998 Silverado 2500HD 5.7L - 4x4 w/ Eaton Locking Diff 348,000 MILES 1993 Silverado 2500 5.7L - 4x4 w/ Eaton Locking Diff 449,000 MILES |
01-24-2006, 03:12 PM | #17 | |
Regular pan drains/filter replacements and flushes (at different intervals) have kept my 4L80E happy for over 307,000 miles and still as smooth as can be.
01-30-2006, 01:36 AM | #18 | ||
Also, do any of you guys run a deep pan to hold a few extra quarts of atf? |
01-30-2006, 06:58 AM | #19 | ||
No drilling was necessary. I used an inline sending unit (sensor). It goes in the transmission line close to the transmission and uses compression fittings with a spade connector for the electric signal to the gage. The only key is to make sure you install the sending unit on the line flowing to the radiator/tranny cooler. There are other types out there that let you drill and install the sending unit in the pan itself, but I liked this method better. |
01-30-2006, 08:02 PM | #20 | ||
01-31-2006, 09:33 AM | #21 | |
[quote=wonder squirrel]Do you remember what kit you bought? This sounds like a pretty easy install and a good way to do it overall
---------------------------------------------------- I used a kit from B&M the tranny builders. It also used the tee in the line which came in the box. After looking at 3 gauges that NAPA got in, I decided the numbers were too compressed in the area of normal operating temp. Then I remembered a speed shop so I went there and they showed me a kit from B&M. I immediately bought it. The numbers are in the correct range, and the face is color coded for a quick glance. The kit even included a mounting bracket. Bob B |
01-31-2006, 05:06 PM | #22 | ||
01-31-2006, 06:59 PM | #23 | |
Did you guys just cut into the steel tranny lines and use rubber hose for the T fittings? Or is there already just rubber lines running out to the cooler?
My 89' had steel lines, so I'm assuming they still use those today even (I'm too lazy to go outside and look right now) <- that smiley is funny |
02-01-2006, 10:14 AM | #24 | ||
My 97 had steel lines. BTW, NAPA showed me three gauges, one was VDO. But they all were too compressed at the temperature of interest and went wat too high so the face was hard to use. Maybe the one mentioned previously is better. The B&M is very much better especially for a quick glance. The B&M part number is 80212. Bob B Last edited by Bob B; 02-01-2006 at 11:09 AM. |
02-15-2006, 10:17 PM | #25 | |
definetly flush it but do the filter as well
02-28-2006, 09:14 PM | #26 | |
pull pan, swap fluid and filter, do this every 30K unless you drive the truck hard or tow a lot, then do more often.
02-28-2006, 10:34 PM | #27 | |
I've heard many bad things about flushing. Why risk it.
Had a 1991 Range Rover with 178,000 miles; I drained the Chrysler tranny every third oil change starting at about 100K. It cost $6 gallon of quality ATF. Cheap compared to replacement. Only 1/4 of the capacity comes out each time, So after 5 changes it's basically all new fluid. It ran smoooth... on shifts. Acutally improved over time. It had a drain plug which made it a snap at oil change. I have a 1997 Tahoe, drained pan/new filter ay 100K. Soccer mom, car light duty. Filter looked clean. If I was keeping it I would put in drain plug. |
03-02-2006, 05:42 PM | #28 | |
Dear wonder squirrel,
In regard to the deep trans pan inquiry, probably a waste of money. It will take longer for the fluid to reach operating temperature and cause additional expense when you service the trans. You ARE using at least Mobil 1 ATF ($5 qt.) and preferably Redline D4 ATF ($10 qt.), aren't you? If you think your trans is overheating, install a good cooler on the front of the radiator. Your local trans expert can advise best size for your loaded vehicle weight and climate. |
03-02-2006, 05:57 PM | #29 | ||
AF - Advisor
A person needs to stay with the transmission fluid that the manufacture calls for in his car/truck for it to have a long and happier life. MT
03-02-2006, 06:41 PM | #30 | |
Never flush it unless you want crap in your transmission. It's like a junkie using a dirty needle.
Change the filter clean the pan and refill with a quality fluid. |
