Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums. |
10-30-2010, 10:12 PM | #1 | |
93 Cutlass Supreme Low coolant light and check engine light
Hi all, Had a "low coolant" light supposedly fixed in 08/15/09 at the radiator shop. The light comes on, on the freeway and goes off when i get back into town. This has been doing this the past couple months, but when i check there is enough radiator fluid in the reservoir. Now i get the "check engine light" below it. I'm thinking of trying to fix this low coolant light myself. I know the radiator has to be drained to replace this "low coolant switch" and an o-ring is needed. Q: How hard is it to do yourself and can someone outline the tools and steps needed to get this down myself. Once I fix that, i'll see if the check engine light comes on again. My details are in my signature below Thanks again! Kevin in Vancouver, WA BTW: I don't even know if there is a code reader still made for this and never used one, so i guess we'll get to that when the radiator coolant switch is fixed? something also has put "&" in my text..don't know what that is all about.
1993 (Calif. model) Cutlass Supreme "S", 3.1 Liter V-6, Multi-Port Fuel Injection, 4 speed (AT), Vin "T" motor, NO Tach. 168k+ miles. |
10-31-2010, 03:19 PM | #2 | |
Re: 93 Cutlass Supreme Low coolant light and check engine light
I checked the overflow reservoir and it's a tad under full for cold...about 3", but the radiator is topped off (cold check). I started the car and the check engine soon light disappeared. I've sent an e-mail to the radiator shop to see if they can look at this low coolant switch and repair it. I had a radiator and the switch repaired there, (the switch on 2009, new radiator in 2007), but wonder if the switch is faulty.
04-26-2011, 01:30 AM | #3 | |
In the 96 Supreme, the low coolant sensor is on the left side of the radiator, 4 to 6 inches from the top. It is pressure fit into a neck similar to a radiator filler. Look for wires going to the sensor.
More likely you need to bled air from the cooling system. My 96 has 2 points, one near the waterpump/heater pipe area. The other is on the right top. |
