| Latest | 0 Rplys |
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines. |
06-05-2011, 02:07 PM | #1 | |
Trouble with car jerking
Hello,
After a long trip, I observed that my car is jerking when it is in gear and is at stop. when I put it in neutral and remove the foot of the clutch, the jerking stops. Even when foot is on clutch and gear is neutral, there is not jerking. The mechanic says there is nothing wrong with it. it usually happens after driving for few mins. Please help. Any help will be appreciated. Thank you |
06-05-2011, 02:31 PM | #2 | ||
Re: Trouble with car jerking
I guess none.. Maybe clutch doesnt disconnect totally? Swap clutch fluid as your symptoms points to heat&water in fluid = never serviced. No help? Clutch adjustment, then if that does not help, clutch assembly swap... Can u define the word "jerking"
. Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507 There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14 |
06-05-2011, 02:50 PM | #3 | ||
Thanks for replying |
06-05-2011, 02:57 PM | #4 | |
Sorry forgot to mention, its 99 Nissan Maxima SE, with 115K miles on it
06-06-2011, 12:38 AM | #5 | ||
The only way is to get the mech into the car while this noise is ON - so he can hear it. My guess it that your exhaust pipe flexible part is worn out and gets noisy in this particular position. (Engine tilts always a little bit when D and brake applied compared to idling N) The noise should be out (or different) when u shift on R as engine tilts opposite direction. Typically exhaust pipe has to be replaced after 100k miles+, depends ... Ask the mech to check the exhaust pipe, its flexible part (and the heat shields which also cause intermittent noises when their supports rust out.)
06-06-2011, 11:03 AM | #6 | ||
Yeah, the car doesn't make noise when reversing. Sorry about the clutch/ brake thing. Thanks for the advice, really appreciate it.
