Go Back   Automotive Forums .com Car Chat > Cars in General > Exterior | Bodykits | Lighting | Aerodynamics
Exterior | Bodykits | Lighting | Aerodynamics Discuss different body kits, body work in general, and all types of exterior modifications.
Old 06-27-2006, 11:46 AM   #1
Misipislim
Questions about Painting My Miata
I have removed the plastic nose cone and rear license plate area on my 1996 Miata in order to paint them.
I have sanded progressively to 400 grit. I do not plan to prime these parts. My questions are:
Should I sand to a finer grit for adhesion?
How long do I wait between coats to sand? and when I do, what grit do I use and should it be wet or dry?
Is sanding necessary between final coat and clear coat?
Thanks
Misipislim is offline   Reply With Quote
Old 07-03-2006, 10:57 PM   #2
dave92cherokee
dave92cherokee's Avatar
Re: Questions about Painting My Miata
If you don't use primer before you paint the parts then the paint won't look that good. If you expect a good high gloss shine to it then always prime before painting. Wet sanding after final coat is a good idea it helps remove any contaminants in the paint and orange peel to give it the best look.
dave92cherokee is offline   Reply With Quote
Old 07-10-2006, 05:40 PM   #3
Misipislim
I have painted the plastic nose and tail of my Miata with acceptable results. How long should the paint cure b4 wet sanding, and what grits should i use?
Old 08-22-2006, 08:16 PM   #4
Greenblurr93
Kind of a Big Deal
Greenblurr93's Avatar
Send a message via MSN to Greenblurr93
24 hrs....ans use 1500 wet and then buff
Greenblurr93 is offline   Reply With Quote
