| Latest | 0 Rplys |
03-08-2010, 06:52 AM | #166 | |
Re: Ned's 91 GSX
Read the VFAQ and Link forums on idle surge. BLT the car, adjust the BISS, etc.
Kris 2012 Genesis Coupe 2.0t |
03-08-2010, 07:13 AM | #167 | |
Re: Ned's 91 GSX
That's all I've been doing is reading. And I did adjust the BISS and my idle has dropped to about 2000 so maybe a sticky throttle plate. I'm off tomorrow and there's a lot to do with adjusting in link. I'm getting a lot of fluctuation on the wb. I turned the fpr up to 40psi even though stock is 37psi. She still wants to stall out after running for about 30 seconds. Is there anything I need to do with link because of the fmic?
03-08-2010, 07:26 AM | #168 | |
Re: Ned's 91 GSX
No changes for an FMIC, but I would BLT the car. Chekc what your TPS is reading in Link with your foot off the gas.
03-08-2010, 08:25 AM | #169 | |
Re: Ned's 91 GSX
It reads 0% but I did the TPSadj feature so if the plate is sticking, it wouldn't know it. I did a BLT and not one hiss to 20psi. Last night when I drove here to adjust the MAFadj, she idled a little better. Started and went up to 2000rpms then started to drop from there but after 30 seconds it wanted to stall. Left the driveway and drove approx. 2 miles and turned around. While turning around the idle was at about 1000rpms and doing well. Drove home and parked her.
03-08-2010, 10:02 AM | #170 | |
Re: Ned's 91 GSX
Also how do I turn the boost down as low as possible so I can started tuning there?
03-09-2010, 01:54 PM | #171 | |
Re: Ned's 91 GSX
Running a lot better, seems like on really cold days is when she wants to stall out after 30 seconds. But once she's warmed up she's fine. I think that might be coolant sensor related? Gotta work out some more kinks. I need help tuning so I posted on ECMforums for help.
03-24-2010, 06:00 PM | #172 | |
Re: Ned's 91 GSX
Tuning setup for 4/13/10 at STM tuning in Rochester.
03-24-2010, 06:54 PM | #173 | |
Holset powered 420a
Re: Ned's 91 GSX
nice, how must boost are they going to tune it on?
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
03-24-2010, 07:30 PM | #174 | |
Re: Ned's 91 GSX
We never discussed it when I called. I want to be safely tuned to a max boost of 16-17psi, whatever is safe for the engines internals.
03-24-2010, 09:25 PM | #175 | |
Holset powered 420a
Re: Ned's 91 GSX
Thats nothing, you got ARP headstuds in yet? If not I wouldn't go above 21-22psi. Some people say it fine to but others say the head lifts above that with a 16g. If your getting it tuned you should go ahead a run it a little harder.
03-24-2010, 10:03 PM | #176 | |
Re: Ned's 91 GSX
I always thought that 18-19psi was the max?
03-24-2010, 11:08 PM | #177 | |
Holset powered 420a
Re: Ned's 91 GSX
nah I would turn it up to at least 20. If you throw in some headstuds real quick you can max those injectors or turbo out
03-26-2010, 11:30 AM | #178 | |
Re: Ned's 91 GSX
If my motor is safe with 20 then I'm down with that.
04-03-2010, 04:15 PM | #179 | |
Re: Ned's 91 GSX
Little update: got rid of my knock by doing new plugs (NGK BPR7ES), can of sea foam in the tank, and a BLT. Had several leaks that included 4 couplers, bov flange, and jpipe at the turbo. Did all that and now I get no knock. Remember the used 255 fp I put in, well that died last night. Ordered another pump, hope it comes in tuesday. Also got a new Hallman RX Pro black MBC, not installed yet but soon.
04-03-2010, 10:11 PM | #180 | |
Holset powered 420a
Re: Ned's 91 GSX
Glad to see you got it all fixed up Ned. Its gonna be a beast when it gets tuned
