I am working on a friends 1997 dodge neon 2.0 DOHC.
The differential pin broke in the tranny and destroyed the tranny case, so we decided to rebuild the engine while we have the engine/trans out. Well got the rebuild done, had a slight knock. I thought it was just noisy lash adjuster. Well about 2 week later it started knocking bad and loss of oil pressure. So I tore it down and found a spun bearing on #3 cylinder. Replaces the crank w/ a remanafactured crank, connecting rods (eagle h-beams), and piston and rings again, all bearings again. Everything was done to spec.!
Got everything back together, except for radiator and coolant, started engine and had still had a knock bud after a few seconds the noise subsided some, no oil light, let it run for a minute or so, then oil light came on and a few seconds later oil starts pouring out of the back of the water pump (where lower rad hose connects to) I'm at a loss, the only thing I can think of is a cracked block. Any suggestions, ideas, common issued?????
Thanks Joe.
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
