Go Back   Automotive Forums .com Car Chat > Ford > Escort
Old 04-07-2011, 07:01 AM   #1
dlbdata
95 Escort Monroe Quick Struts
I just ordered a couple Monroe Quick Struts for the rear, since I had 2 broken springs. I have 1 side removed and trying to install the new quick strut, but I'm having a tough time trying to get the spindle holes to line up with the strut holes. The top of the spindle is rotated out & to high up, but it seems almost impossible to get it in position. Any tips on how to get this done?
dlbdata is offline   Reply With Quote
Old 04-08-2011, 02:10 PM   #2
denisond3
Re: 95 Escort Monroe Quick Struts
I took the brake drum off, so I could slide a length of pipe over the end of the axle, to lever it up, moving the strut mounting holes closer into position. I also had a long steel pipe I was using to push the rear axle (and the spindle) down a little bit. Then I was able to get the end of a tapered 'line-up-tool" through one of the holes in the strut and the spindle. From there I used a larger tapered item (the business end of a rock hammer) I had, to get the holes lined up so the original sized bolts could go back in.
I bought a set of the line up tools and small diameter 'pin punches' years ago in a Sears store. They have been very useful.
denisond3 is offline   Reply With Quote
Old 04-15-2011, 11:19 AM   #3
zzyzzx2
Pics? I do not remember having any trouble with this.
zzyzzx2 is offline   Reply With Quote
Old 04-16-2011, 04:27 AM   #4
dlbdata
Originally Posted by denisond3 View Post
........Then I was able to get the end of a tapered 'line-up-tool" through one of the holes in the strut and the spindle. From there I used a larger tapered item (the business end of a rock hammer) I had, to get the holes lined up so the original sized bolts could go back in.
I eventually muscled it into position with all my weight/strength while someone else tried to slide the bottom bolt in place. Once we got the bottom bolt in, I jacked underneath the drum (with block of wood) which rotated the to hole into position. It's an easy job other than trying to line the bottom mounting holes up. Yes I could see how the tapered line-up tool would have been helpful.... Best part of the whole project, one of the struts they sent me had the spring mounted wrong. I got a free upgrade from the EconoMatic to the SensaTrac model.
2000 Grand Prix Strut Replacement mikepieronek Grand Prix 8 05-05-2010 08:40 PM
Monroe Quick Strut repeated problems????? redgtxdi Camry/Camry Hybrid/Vista 41 04-11-2010 07:13 PM
monroe quick struts franger Windstar 5 07-25-2008 08:35 PM
Monroe Quick Struts. dannyv23 Camry/Camry Hybrid/Vista 9 08-11-2007 05:00 PM
