Go Back   Automotive Forums .com Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 05-10-2016, 09:29 PM   #1
Jleyva
Angry A/c help please!!!
I have a 1998 dodge ram 1500 5.9 the ac blows hot I've replaced the ac compressor the evaporator and the ecumulator I even did a ac vaccum on the lines their are no leaks but I can't figure out what the problem can be please help !!!
Jleyva is offline   Reply With Quote
Old 05-10-2016, 09:37 PM   #2
harleyguy
Re: A/c help please!!!
Is the compressor kicking on and is the engine cooling fan turning on?
When you changed things did you add the right amount of freon and oil?
harleyguy is offline   Reply With Quote
Old 05-10-2016, 09:39 PM   #3
Jleyva
Yes the AC compressor enguages and the fan turns on to but still blows hot air
Old 05-10-2016, 09:40 PM   #4
Jleyva
Yes the right amount of freon was add and oil to
Old 05-10-2016, 09:49 PM   #5
harleyguy
Have you put a gauge on it what pressures do you have?
When it's running does the low side pipe get cool at all?
Old 05-10-2016, 09:51 PM   #6
Jleyva
Yes when I add freon the pipe or line does get cold but but dosent blow cold air through the vents and the guage pressure goes all the way to the red side.
Old 05-10-2016, 10:40 PM   #7
harleyguy
Sounds like a blockage somewhere. Did you change the orifice tube when you changed everything else?
Old 05-10-2016, 10:43 PM   #8
Jleyva
When I added the freon I noticed their wasent an orifice tube in their. But I thought the orifice tube wouldn't really do much if I add one and add freon again thinking I might get the same results
Old 05-11-2016, 02:27 AM   #9
harleyguy
You should have an orifice tube or expansion valve. Something has to be there to regulate flow. Did you flush the system and blow air through it?
Old 05-11-2016, 03:11 AM   #10
Jleyva
Okaybi will fint one and no I did a vacuum on the lines inatead. Do you think it will help to do a flush
Old 05-11-2016, 04:42 AM   #11
harleyguy
It wouldn't hurt I always do when replacing a compressor. Just so you know you don't get chunks of old compressor in the system.
Old 05-11-2016, 09:32 AM   #12
Jleyva
Even though my evaporator is brand new and my AC compressor is new should I still do a flush
Old 05-11-2016, 02:42 PM   #13
MikeCStig
It sounds like you didn't replace all of the lines. You don't have to, but if you don't, yes the system should be flushed. You may discover that some kind of blockage in the lines is the source of your problems.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
MikeCStig is offline   Reply With Quote
Old 05-11-2016, 04:19 PM   #14
Jleyva
Okay thank you guys for the feedback I will flush out the system and hopefully it start blowing ice cold again
Old 10-12-2016, 05:49 PM   #15
the61
My vent door was not opening I got it open and put a screw to hold it till I get time to chase down the problem.
If one pipe is cold and one hot it's flowing. Check the vent door.
the61 is offline   Reply With Quote
