| Latest | 0 Rplys |
10-09-2005, 04:58 PM | #16 | ||
Re: Re: Help - 1999 tahoe, Cranks but wont start when Temp is near 210
Sorry for got to say in my last reply... No go, didn't work. I don't think its a security issue anymore. It has to do with anything involving fuel injection and or sensors. |
10-11-2005, 08:46 PM | #17 | |
I'm kind of cirious about somthing,if power comes on, the engine bumps over but never runs. At 210-220 temp when you turn the key do you hear the fuel pump pressurize the fuel system if so there are 2 sensor's maybe more but I know you have a Temp coolant sensor located on the thermastate housing. Second there is an air temp sensor located onthe upper half plenuim ( MPI fuel sys). Which could be dectated by the lineare EGR valve if it is stuck open. Give that a try.
10-11-2005, 10:51 PM | #18 | ||
10-12-2005, 11:12 PM | #19 | |
hey man I'm pretty sure you found your problem. Remember it takes 55-60psi to operate a multi port injection, if you got a tank full of crap well, it wont run, it probably in the morning but once its stured & sucked up in the pump and filter it wont have the fuel pressure required. By the way when you turn the key on (radio off ) under the truck you can hear the fuel pump ZZZZZZZZ.. pressurizing the system, if that happens then you know your fuel pump is still good.
11-08-2005, 06:14 PM | #20 | ||
Hey Yeah I think I found it too. Hasn;t been happening. Yeah THat was it, the filter blocking the proper pressure. Also Yes I hear the ZZZZZ sound. Right now I have another problem with my truck, not as bad, but but I amgoing to post a new topic about it haha.. my never ending problems.. |
