04-12-2004, 10:50 PM | #1 | |
!!! ABS & "Check Tire Press" Light On! HELP!!
Today, i was driving my car and both lights turned on out of nothing. I noticed that the power steering feels little harder. I sent my car to the mechanic shop and diagnose my car with OTC Tool but no codes were found. What can I do. I tried the ABS braking and the front wheels got locked, then i supoused that front ABS System doesn't work. Please help me !!!!!... I hate that lights on my dashboard.
Thanx MoshimoGTP 97 Coupe GTP 96K Miles |
04-13-2004, 11:42 AM | #2 | |
Re: !!! ABS & "Check Tire Press" Light On! HELP!!
This has happened to my wife's GTP...I disconnected the battery, removed the wheel sensor connectors and blew them out with compressed air. Plugged them back in and reconnected the battery.
Hope that is all it is with your car. Other's have reported that their wheel sensors have gone bad. Also, there is a button to reset the Check Tire Press light under the dash on the drivers side. Since your ABS light is on too I don't think that will help, but can't hurt. Good luck |
04-13-2004, 07:08 PM | #3 | |
same thing happened to my car a couple weeks back...i just reset the tire pressure system and turned the car off. when i turned it back on everything was fine.
04-13-2004, 10:36 PM | #4 | |
Sonhasteg, that really works =). Thanx you a lot!
04-13-2004, 11:00 PM | #5 | |
yeah it worked for me to, for about 2 months until i was 2400 miles away from home and my wheel bearing was humming that why mine came on, your about the mileage when they do go. check it out test it see if the wheel moves from top to bottom if you have play, its not good that your problem. (jack you car up to check it out FYI) if you need pics to do it yourself let me know i took about 30 pics while doing it to help people out on what to take off
1996 Ranger with 249,xxx miles on it...
was my beater now my daily driver, still trying to figure out how that happened 99 MXZx 440 SNO PRO Forsale 89' Honda TRX 250R |
04-14-2004, 02:23 AM | #6 | |
Thanx Rockford, if you can please send me the pics to do the test with my GTP, my car has 95k miles. My email is jcorvera@beamspeed.net
Thanks! MoshimoGTP |
04-14-2004, 10:50 PM | #7 | |
I sent 9 pics on how to take of the wheelbearing, i would have sent more but i have dial up and it took 50 minutes just to upload those 9. If you still have questions let me know ill try to help you out
04-14-2004, 10:58 PM | #8 | |
Thanx rockford...
MoshimoGTP |
04-15-2004, 11:43 PM | #9 | |
I have a '97 GTP and the abs and tire press. lights came on. Hooked it up to a scan tool and found that it was the hub assemblies. I replaced them both and now it's fine.Autozone sells the hub assys. for $123.99 each. I took the old ones apart and found a lot of water in them. This seems to be a very common problem. It's a pretty quick and easy fix though. Hope, that helps!
