Go Back   Automotive Forums .com Car Chat > Car Audio
Old 12-13-2006, 09:53 PM   #16
SlackerOfSociety
SlackerOfSociety's Avatar
Re: HELP! ASAP! Potential FIRE!!
Originally Posted by sr20de4evr
It's a pyramid, it's not 1600 watts, you'd be lucky if it was 300
I'm saying the amp probably blew because it's a Pyramid which is quite possibly the worst brand there is in this hobby, but before you hook up any other amp you need to check what impedance the speakers are wired to because whoever installed it may have wired them to some ridiculously low impedance that would blow any amp that tried to power them.
So how do I go about doing that? the speakers are wired with 16 gage wire i believe. is that what your talking about?
SlackerOfSociety is offline   Reply With Quote
Old 12-13-2006, 09:56 PM   #17
sr20de4evr
sr20de4evr's Avatar
no
the first step is buying/finding a multimeter, then you just set it to measure resistance and put the terminals on the wires coming from the box (make sure to disconnect them from the amp first).
That's if you want to do it practically, if you want to do it theoretically then you need to find out the impedance and voice coil configuration of your subs and figure out how they're wired (series, series/series, series/parallel, parallel, parallel/parallel) and you can figure it out that way.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
sr20de4evr is offline   Reply With Quote
