Go Back   Automotive Forums .com Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX > Technical
Technical Discuss Engine, Suspension, Drivetrain, and all other technical issues here.
Old 04-28-2008, 11:06 PM   #1
Tyler2007
? ? How ? ?
Well .. then ill start off by saying lil new to imports ... never owned one but am going to purchase one .... now then i am going to buy a 240sx .. i have always loved the way they look and i like nissan so i figure its best , i have chosen a import cuz gas is to freakin exspensive ... i want a mustang but the mpg are not very appealing anyway i wanna have some power in it so i wanna turbo charge it .... now then i have looked around for a kit and there all about 3500 or so and i dont wanna spend that much so i thought id make one my self ... ( my dad is very good with cars) anyway i just didn't know if anyone has a setup that would work for me ... anyway long and short what all would i need and can i atleast get like 250hp out of it ? ... with stock intervals ... anyway thanks for the help ...
Tyler2007 is offline   Reply With Quote
Old 04-29-2008, 03:31 PM   #2
Firewind
Firewind's Avatar
Re: ? ? How ? ?
Well to keep it cheap, you'll have to buy some used parts. Not broken parts. ;P
If you plan to go turbo, dunno if you have your car yet, but you will need to consider a few things like how many miles are on your car, and can your car handle a turbo. Check your compression raitos, and consider rebuilding for hile milage motors. On a stock KA24 motor you can push about 7PSI and be safe. Though any higher isn't recommended.
for a build around $2000-$3000 depending on how froogle you are looking around 200-230WHP, you can maybe do more.. but a basic setup would be some 370cc fuel injectors, fuel control, ECU management system for tuning, most likely atelast a T28 turbo (NOT FROM EBAY!!), turbo manifold (Also do not recommend ebay, they crack easily), blow off valve, bigger exhaust, an intercooler, and a bit of tuning. You may even need to consider looking at a better MAF. It ads up quick, and can be a lot of work.
One thing I can tell you is getting a 240SX with a KA24DE (Dual over head cams) which is tipically found in 1991 and up 240sx, you'll have more power then the older singel over head cam KA24E.
Of course there is one other option. SR20DET motor swap, but that'll run you about 3 grand + some from most people I have talked to.
Hopes this helps.
Firewind is offline   Reply With Quote
Old 05-29-2008, 02:04 PM   #3
slideways...
slideways...'s Avatar
Re: ? ? How ? ?
i have a turbo manifold, injectors, head gasket, and a downpipe for sale...
all brand new, turbo manifold has external wastegate flange, and is flanged for a t3 turbo. 600 for the manifold/downpipe/oil lines/hardware, 300 for injectors, 85 for the heavy duty headgasket. i can ship too let me know.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
slideways... is offline   Reply With Quote
Old 06-01-2008, 12:09 AM   #4
Miles Prower
Re: ? ? How ? ?
GT2860R 900$
Ebay Manifold/Elbow/Downpipe 250$
Q-Garage Reflash 350$
Used STi Injetectors 350$
Z Maf 100$
Waterlines 100$
Fuel Pump/Filter 100$
Ebay Intercooler 250$
Various SR bits to make it work 150$
Thats around 2k
will make around 260whp at 12psi 300 or so at 18ish.
No Hooptie shit non ball bearing turbo
Still Barely passable though.
and its KA so I'd expect it to blow up.
"A criminal hiding in plain sight ought not wave red flags lest he desires to lead the authorities right to him."
Miles Prower is offline   Reply With Quote
