| Latest | 0 Rplys |
11-04-2006, 07:11 AM | #16 | |
Re: 94 non responsive
Yes. The regulator and spider are INSIDE the intake.
CD 1991 W41 #142 1989 Caprice 9C1 1997 C1500 1997 Bonnie SE 1998 Olds 98 LS Recently updated: http://forums.b-body.org |
11-07-2006, 11:04 PM | #17 | |
how long would it take someone who has never done one b-4 guesstamite? what would cause the back fire in intake? why would it quit when you turn it off and back on? im frustrated with it!! thanks...
11-15-2006, 01:10 AM | #18 | |
i have not attempted to mess with intake i left the van with a buddy who seems to think its the coil.. can a coil cause these ploblems? im a pick one up this week end and bring it to him.. its sparking between the copper inside plastic to the meatal around coil..
11-15-2006, 08:38 AM | #19 | |
Any time you find arcing around the coil going to ground you have problems.
Arcing anywhere its not supposed to be will cause problems. |
11-18-2006, 10:33 PM | #20 | |
changed coil it still acts up after 15 min of driving back fires trew intake and exhaust.. turn it off and restart it its fine for 15 more min
12-27-2006, 02:40 AM | #21 | |
still acting up but its getting worse so now the intake has ben removed and fuel preasure regulator changed, i guess wires and injector checked out.. the computer has ben changed ingiton modual,plugs,wires,cap,rotor,and coil.. it still runs great but then after 15 min it runs like a dog hesitating severly it is getting worse.
12-27-2006, 11:26 AM | #22 | |
I would check for a bad electrical connection or defective wire. Put your hand on the wire to the connections and wiggle them and try to find the bad connection. I have found a lot of people pull hard on the wires to disconnect them and a wire breaks to the terminal.
12-31-2006, 03:24 AM | #23 | ||
