| Latest | 0 Rplys |
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all. |
07-15-2007, 03:28 AM | #1 | |
z32 water prob's help please
My TT 300zx is burning up the water and blowing steam from one exhoust only, she makes a loud howling noise from the same side under boost, i ran a compression test and that is all good. can it be a head gasket or a turbo??????? Barry
07-15-2007, 01:49 PM | #2 | |
Re: z32 water prob's help please
bhg baby!
ZedEx Crew Member #6 1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc. blown turbo, under construction.. gt35 coming. |
07-16-2007, 04:40 PM | #3 | |
Sounds like headgasket failure. cheap and easy fix.
Finaly got pics of my car....... after I washed it of course. |
07-23-2007, 12:18 PM | #4 | |
Head Gasket kicked da bucket....
07-23-2007, 03:57 PM | #5 | |
how could it be the head gasket if he compression tested it and it passed?
symptoms sound like the hg but if he comp tested it...... Are the turbos water cooled? What about the intake gaskets? does coolant flow through the intake? A comp test should reveal a blown head gasket.... let me rephrase that a compression test when properly done WOULD reveal a blown head gasket.... unless the z32 defy the laws of physics....(no not just because you smoked a mustang like he was sitting still either that doesnt count...) Read carefully he stated that he compresion tested.. |
07-25-2007, 02:27 PM | #6 | |
ur kidding me right you can have a bad head gasket and still have good compression infact i have seen this many times on differant cars ...
oh and when done right .. hmm there is nly really one way of doing a compression test so there is only one way to doit ..
Past Z Car Crew [The Enemy Of Your Enemy is Your Friend] >>Keep Your Friends close : But Keep Your Enemies Even Closer << |
07-25-2007, 05:22 PM | #7 | |
Cheers guys.- As above there is only really one way to compression test, and yes I did it properly - the same way I have tested a hundred other motors - and yes it was all good.. Pulled the head anyway and found patch with half a dozen little pin holes in the gasket, which was obviously not enough to leak compression but was just enough to suck a bit of water through.. Replaced it and she's all good now, no steam. :o)
