Go Back   Automotive Forums .com Car Chat > Chevrolet > Malibu
Old 05-27-2016, 03:57 PM   #1
kennyhawk46
POSITRACTION for FWD
not sure if im in the right place but here we go.. I have a 99 Malibu 3.1 FWD want to see if there is an easy way to make it positraction.(for racing on dirt oval) besides buying the limited slip.
kennyhawk46 is offline   Reply With Quote
Old 05-28-2016, 02:16 PM   #2
MikeCStig
Re: POSITRACTION for FWD
Positraction thrives in straight lines. The reason being that it has more of a tendency toward locking the drive wheels together for even distribution of the power. That will present a challenge on any type of circuit with corners, including a simple oval track and especially on dirt. If it were RWD it could work to your advantage depending on your driving style. With FWD, it's the last thing you want unless you're just drag racing. When you turn, the wheel speeds on both sides won't really adjust to the turn like you want them to, instead they'll want to keep going the same speed. The result; hideous understeer. They'll adjust slightly, but there are much better limited slip differentials for your purpose.
"Ok, systems check; the battery is discharging, the oil temperature is very high, the oil pressure is very low, the engine temperature is off the end of the scale, I'm running out of petrol... but the clock is correct!"
-James May, in an old, worn out Lamborghini purchased for less than £10,000.
MikeCStig is offline   Reply With Quote
