Go Back   Automotive Forums .com Car Chat > Plymouth > Breeze
Old 04-11-2009, 03:05 PM   #1
baseball1
98 breeze rear brakes don't release
I just did a brake job on my sons 98 Plymouth breeze. When I pressure up the system the rear brakes don't release. I've done the brakes b4 and never had a problem. With the drums off I can't even push the cylinders back together. They don't release until I crack the bleeder. What's going on? Thanks
baseball1 is offline   Reply With Quote
Old 09-16-2009, 03:01 PM   #2
scuzzo
Re: 98 breeze rear brakes don't release
I'm sure you have figured this out by now, could you let me know what is going on as I have the same problem. I have posted a similar topic in this forum.
scuzzo is offline   Reply With Quote
Old 03-05-2010, 08:13 PM   #3
dnmir54
r3emove your brake shoes and inspect the shoe pads on the backing plate ,you may find a line running thru the pad the shoe may be sticking or hanging up in this line , this is what happened on my daughter 98 breese
remove the backing plate weld up the pad area and grind it down flat again
this is a common problem with the breeze
i went to a junk yard to get a different backing plate and that one was bad also
dnmir54 is offline   Reply With Quote
Old 03-06-2010, 07:08 PM   #4
dnmir54
do you have porpotioning valves on this car,this might help
Old 03-24-2010, 09:20 AM   #5
baseball1
The problem ended up being the short brake line between the rear brakes and the connection mounted on the frame. It's about a foot long, rubber with metal ends. It was suggested that in all the moving around a small piee of crap got loose and blocked the fluid from going back. I replaced it and problem solved. Thanks
