Go Back   Automotive Forums .com Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 01-22-2018, 03:59 PM   #1
4xtra
2000 Toyota Camry Issues - stalls when warmed up
I have a
2000 Toyota Camry 4cyl and replaced the following:
Cam Shaft Sensor
MAP Sensor
TPS
Spark Plugs
Timing belt (I do suspect this maybe is off because the issues STARTED after someone replaced this)
Front Break pads
Radiator
Vehicle Speed Sensor
PCV Valve
EGR Vacuum Modulator
Crankshaft Sensor
Clean EGR
Fuel Pump The pump was replaced and I had to rewire this)
Fuel Filter
I plan on replacing the KNOCK SENSOR when that part gets here....
And I am still getting
P0171
P0300
P0301
P0302
P0304
P1780 (Park Neutral switch)
codes
The car starts after 2-3 turns of the key but when the car warms up, the misfire begins and STALLS OUT within 5-10 miles.
The car will start 30 minutes later.
When it was very cold, the car ran FLAWLESSLY
so that means that when something gets hot..... it stalls the car.
What the heck is wrong here?
4xtra is offline   Reply With Quote
Old 01-27-2018, 08:09 PM   #2
ukrkoz
ukrkoz's Avatar
Re: 2000 Toyota Camry Issues - stalls when warmed up
Vacuum leak somewhere. Warms up, metal expands, leak starts. Try carb cleaner test.
ukrkoz is offline   Reply With Quote
Old 01-27-2018, 08:15 PM   #3
4xtra
I did that and there was NO change in idle.
I made sure I sprayed around the intake to see if there was a intake gasket leak and no change what so ever.
