Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive. |
10-31-2003, 05:44 PM | #1 | |
tokico???
i have a prelude 2001 with h&r sport springs on it...im looking for shocks/struts...what should i get tokico HP, koni yellow, or the tokico illuma???
i dont know squat bout what does what...i just want a decent set!!! thanks |
10-31-2003, 11:12 PM | #2 | |
Re: tokico???
Get the Koni Yellows - 2nd choice illumina
shocks/struts/dampers are devices that control unwanted movement of the spirngs, without them your car would continue to bounce, droops at stops, & handle terrible. Shocks do not hold the car up, springs do - they also dont absorb bumps, springs & tire side walls do - shocks absorb energy created by the chasis, springs, & tires. OEM shocks do not have enough valve capacity to control shorter/stiffer springs - the more a shock works, the hotter the fluid gets & that makes them not perform as well - AKA shock fade. That is 1 reason not use sotck shocks with lowering springs & another reason is that the piston may travel so fast that it WILL blow out seals. |
10-31-2003, 11:25 PM | #3 | ||
Re: Re: tokico???
