| Latest | 0 Rplys |
04-03-2008, 03:17 PM | #46 | ||
Re: Wideband o2 ~ $110
04-03-2008, 03:24 PM | #47 | ||
Holset powered 420a
Does the timer actually say 14.7 or is it the raw o2 sensor voltage? I always thought that the apexi timer just displayed the voltage. Like .92
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
04-03-2008, 03:47 PM | #48 | |
Holset powered 420a
Ok man, I looked up some info on the apexi turbo timer. It looks as though the timer can display both the raw voltage and and actual a/f ratio. What you need to do is hook up the a/f wire going to the TT to one of the Vouts on the JAW unit. Configure that Vout for a narrow band sensor. This will make the outputs only 0-1v which is what the TT wants. The TT will take this voltage and convert it to an a/f ratio. This should work fine but I would compare the data on the TT to a laptop to make sure the values are accurate.
04-04-2008, 04:31 PM | #49 | |
Dave:
It took like 3 weeks for my JAW to come in. Yeah I usually don't deal with NAPA either, they're crap is so high priced. A fuckin set of axles for my car were $200 and I had to buy them because Advance couldnt get the right ones. Anyways, NAPA is the cheapest joint to get the wideband sensor from, even cheaper than the I-net.
Caleb vanilla gorilla '99 Spyder 2.4 5-speed - Red/black,14b,slow '96 Eclipse GST 5-speed - Paint www.myspace.com/ballsoutperformance |
04-04-2008, 04:37 PM | #50 | |
Holset powered 420a
But you got your assembled so it took a little more time. I have been telling everyone that Napa has the cheapest price on that sensor. I looked everywhere for it. I usually dont get things from them either but ocationally.
04-04-2008, 09:49 PM | #51 | |
Jizzed In My Pants
Napa is usually re-goddamn-diculous as far as pricing goes, but on some things you get lucky... these sensors are one. Guages are another, I got my autometers from them. IIRC if I would have bought them all on eBay I would have saved about $10, but with napa you get them 2-3 days after you order them.
04-10-2008, 03:37 PM | #52 | ||
04-10-2008, 04:32 PM | #53 | |
Holset powered 420a
Ah I get it now. Yea that should work fine to read the WB with. Like I said earlier just run it off the vout1 and set that channel to opporate on the NBo2 sensor range and it should be fine. It maybe be a little off depending on how the apex unit turns the voltage back into the AFR but it should be close for the most part.
04-10-2008, 05:39 PM | #54 | ||
04-11-2008, 07:41 AM | #55 | |
Holset powered 420a
Yea I will help you set it up. The TT will display the actual AFR, but the unit is made to work off a NB signal which is 0-1v. A WB signal is 0-5v. So you will have to tell the JAW to send it a NB signal so the TT can understand it and change it back into a AFR.
04-14-2008, 07:06 PM | #56 | |
will i be able to have the turbo timer read a/f while logging the wideband with dsmlink simotainously (s/p) **at the same time?**
04-15-2008, 07:13 AM | #57 | ||
Holset powered 420a
04-15-2008, 10:55 PM | #58 | |
Tight!!!
04-21-2008, 11:35 AM | #59 | |
Dave is THAT guy
Just an update, the forum on the website has been redone to stop the porn, so it's much easier to get around, even though the posts have been whipped out.
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
04-21-2008, 01:55 PM | #60 | |
Holset powered 420a
Wow thats awesome I was waiting for that to get fixed. Did you contact him about your JAW Dave?
