| Latest | 0 Rplys |
12-28-2007, 08:37 PM | #16 | |
Re: Short Circuit or bad alternator? '87 B250
I think you have a drain on the battery which is excessive. Disconnect the battery ground use a DVOM set to amps and check the draw between the ground clamp and battery negative. You might to disconnect a fuse at a time to find the problem. The tail lights have a switch by the brake pedal poor adjustment or a bad switch will cause problems. The trailer brake unit can be disconnected. Let the vehicle set over night and check if this helps.
