| Latest | 0 Rplys |
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums. |
03-30-2006, 12:15 AM | #16 | |
Re: 89 Oldsmobile Cutlass Questions
One option is to remove the computer you now have and reflow the solder on every solder joint. A little tedious but, if your used to soldering, no big deal.
03-30-2006, 01:43 AM | #17 | |
Yea, if you are good with soldering, that would do it...me, I couldnt solder to save my life.lol Everytime I try, I fail miserably and make a mess...also, I guess I just dont have the patience to learn do do it more effectively...
03-30-2006, 03:04 AM | #18 | ||
Since our cars use the same engines, the ECMs may be interchangeable so here are some pics of my spare so you can compair them to yours and figure out if they are interchangeable(but Im not holding my breath)... http://img95.imageshack.us/img95/2554/img01257il.jpg http://img86.imageshack.us/img86/2985/img00975td.jpg Well there it is... |
03-30-2006, 09:45 PM | #19 | |
Yeah, that one will not work. Mine is the weatherproof style that sits under the hood. It also has 4 connectors that go into it. I did find out that the 1227727 is pretty much the same unit as a 16149396, just that the 2nd one has more memory in it. These are the 2 ECMs that I have currently.
Also, could the ECM be causing the digital dash and the message center to not come on? The dash shows nothing, and the message center either shows nothing or just garbage. I have tried both of my ECM's and get the same results. |
03-31-2006, 06:47 AM | #20 | |
Pontiac Guy
If the car has a body control module that is probably the problem with the message center and possibly the dash.
03-31-2006, 08:14 AM | #21 | ||
04-11-2006, 09:30 AM | #22 | |
This past weekend I picked up a replacement ECM for the car and guess what! Still the same issue! hehe. I now have 3 different ECM's that all produce the same result, nothing. When I turn the key to the run position the charge light on the dash comes on, but nothing else. When I try to crank the engine over, the check engine light comes on and stays on, unitl I stop turning the motor over. I cannot get the computer to show me any codes whatsoever. I have checked the C100 & C200 connectors in the engine comparment and under the dash and they appear to be connected well. I have also checked and replaced any blown fuses in the car. Is there somthing that I could be missing? I know there is a fuse for the ECM under the hood and in the fuse block, are there any others that I should check? Any further ideas or suggestions are appreciated! Thank you!
04-11-2006, 05:47 PM | #23 | |
Pontiac Guy
Run a seperate ground to the ecm and make sure you have a good ground connection. This sounds like a power issue since the CEL comes on when you crank the engine and not when you just have the key on. Also check the hot wire to the ecm with a volt meter. If there is no voltage except when cranking then you have a problem with power. I would check the fusable links at the starter as one may be bad. Good Luck
04-12-2006, 03:56 PM | #24 | |
Edited
04-17-2006, 12:51 PM | #25 | |
Well, I have determined at this point that the problem is most likely with the wire harness connector under the hood that connects to the interrior of the car. My next move is the same no matter the final result will be. Since the motor is good, I am going to start the process of pulling it out and rebuilding it. Once I have the motor out, I will have more access to the firewall connector and the rest of the wiring harness, so I may replace it and put it all back together, or I may scrap the rest of the car since it is in rough shape and find another body. My next question is that since this motor originally came out of a 92 beretta, and it is the older style 3.1l v6, does it matter what year vehicle I put the engine into? Or will it need to be a car that originally had that older style of 3.1? Thanks!
